July 27, 2021, 05:03 |
Fine grid for Double wedge test case
Dr. H.K. Narahari
Rep Power: 7 |
I have successfully run NEMO test cases in the repository (inviscid wedge and viscwedge). One of the cases mentioned in the literature is a Double wedge, I was wondering if someone has tried out the case at Hypersonic Mach number. I remember seeing the results in a presentation on NEMO with Mutations ++ by Dr. C. Garbacz et al. I would like to get a pointer to that GRID if it is available in open domain of course. Regards and Thanks in advance Narahari |
hypersonic, nemo |
On grid independent solution for pulsatile flow | David | FLUENT | 5 | March 25, 2022 03:33 |
VOF Grid Independence Test | pokhrel | Fluent Multiphase | 0 | February 20, 2017 15:45 |
Problem with grid sensitive test cases(shock instability) in SU2.!!! | Vino | SU2 | 2 | November 27, 2014 04:33 |
Interfoam Droplet under shear test case | adona058 | OpenFOAM Running, Solving & CFD | 3 | May 3, 2010 18:46 |
coarse grid to fine grid crashing | Arnab | Siemens | 1 | February 22, 2005 12:27 |
