Home > Forums > Software User Forums > SU2
SU2_DOT - Gradients of the "Quick Start" case.
Old   August 19, 2021, 14:53
Default SU2_DOT - Gradients of the "Quick Start" case.
Pedro Paulo
pedropcb13 is on a distinguished road
I am trying to obtain the gradients regarding the drag obj function using the "Quick Start" case. (Continuous Adj.)
However, when executing the SU2_DOT module the output is just a scalar:
DRAG gradient
-0.0180529
I was expecting the output to be a vector, representing the gradient of the surface for the NACA 0012 geometry.
Can someone explain this to me? Is there something I should change in the inv_NACA0012_basic.cfg file to get the gradient to be a vector and not a scalar?
Thanks.
pedropcb13 is offline   Reply With Quote
Old   August 21, 2021, 17:46
pcg
Pedro Gomes
pcg is on a distinguished road
That is the derivative of the design parameters defined in the config, i.e. DV_PARAM= ( 1, 0.5 )
The "raw" geometric sensitivities are in the output file (.vtk .vtu etc.) of the solver.
pcg is offline   Reply With Quote
Old   August 25, 2021, 11:47
Pedro Paulo
Thank you for answering!
gradient, quick start, su2_dot
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
Changing the grid on the same set-up Katya FLUENT 7 October 8, 2009 16:31
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
Turbulent Flat Plate Validation Case Jonas Larsson Main CFD Forum 0 April 2, 2004 10:25
Body force - Does it work? Jan Rusås CFX 5 August 27, 2002 09:50
