LLT factorization failed | CholeskyDecompose() |
Hi Guys,
Just a quick question. Have been trying to somehow accelerate the AD part of an optimization problem because it takes lots of iteration to converge. I mean the primal converge in less than 20k but for AD it goes to somewhat 300k iterations. So I have been trying to modify the below part of my config file to make it converge faster then I got this error: Error in "void CSymmetricMatrix::CholeskyDecompose()": ------------------------------------------------------------------------- LLT factorization failed. ------------------------------ Error Exit ------------------------------- Could you please explain what could be the reason? % ---------------- ADJOINT-FLOW NUMERICAL METHOD DEFINITION -------------------% % % Frozen the slope limiter in the discrete adjoint formulation (NO, YES) FROZEN_LIMITER_DISC= NO % % Frozen the turbulent viscosity in the discrete adjoint formulation (NO, YES) FROZEN_VISC_DISC= NO % % Use an inconsistent spatial integration (primal-dual) in the discrete % adjoint formulation. The AD will use the numerical methods in % the ADJOINT-FLOW NUMERICAL METHOD DEFINITION section (NO, YES) INCONSISTENT_DISC= NO % % Convective numerical method (JST, LAX-FRIEDRICH, ROE) CONV_NUM_METHOD_ADJFLOW= JST % % Time discretization (RUNGE-KUTTA_EXPLICIT, EULER_IMPLICIT) TIME_DISCRE_ADJFLOW= EULER_IMPLICIT % % Relaxation coefficient (also for discrete adjoint problems) RELAXATION_FACTOR_ADJOINT= 0.8 % % Enable (if != 0) quasi-Newton acceleration/stabilization of discrete adjoints QUASI_NEWTON_NUM_SAMPLES= 20 % % Reduction factor of the CFL coefficient in the adjoint problem CFL_REDUCTION_ADJFLOW= 0.8 % % Limit value for the adjoint variable LIMIT_ADJFLOW= 1E6 % % Use multigrid in the adjoint problem (NO, YES) MG_ADJFLOW= NO Is it relaxation factor or number of sampling for quasi-Newton acceleration? |
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel | U.Golling | OpenFOAM Running, Solving & CFD | 52 | September 23, 2023 03:35 |
Initial conditions for uniform flow | andreas | OpenFOAM | 5 | November 16, 2012 15:00 |
[OpenFOAM] ParaView/Parafoam error when making animation | Disco_Caine | ParaView | 6 | September 28, 2010 09:54 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 06:31 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
