Home > Forums > Software User Forums > SU2
Restarting Simulation with Spatial Fourier Activated Giles BCs
Old   February 21, 2022, 09:05
Post Restarting Simulation with Spatial Fourier Activated Giles BCs
Josh Kelly
joshkellyjak is on a distinguished road
I'm running a radial-inflow turbine simulation using Giles BCs and a mixing plane between the nozzle guide vane and rotor zones, similar to the method described in the APU turbocharger test case. My solution runs with the SPATIAL_FOURIER option turned off and converges to the values of mass flow I would expect but the values of pressure at the boundaries don't match the BCs when I process the results in Paraview after. I think this is due to reflections at the boundaries as I observed similar issues when simulating just the nozzle guide vane which was solved by activating the NRBC. However, when I do this with my full simulation it diverges after 2/3 iterations. Is it possible to run a simulation with the NRBC turned off, have it converge to a given point then restart the simulation with it turned on? If not, why does my simulation diverge after a couple of iterations with NRBC activated when starting from scratch. I have attached my .cfg file to this post and any help would be greatly appreciated!
Thank you in advance
joshkellyjak is offline   Reply With Quote
giles boundary, mixing plane, non reflecting boundary, turbomachinery
BCs in an FSI simulation of a flexble pipe vivekcfd OpenFOAM 10 January 8, 2010 04:14
Restarting simulation with a Backup file. Mohammad Faridul Alam CFX 3 November 2, 2007 15:53
restarting lagrange (particle tracking) simulation dbdias CFX 0 September 22, 2007 19:26
Restarting KIVA simulation Tomislav Main CFD Forum 2 April 5, 2006 03:22
Difficult BCs about Freesurface Simulation by VOF Yongguang Cheng FLUENT 0 September 19, 2003 07:39
