February 7, 2023, 10:52 |
SU2 7.5.1 AUSMPLUSM Invalid upwind scheme
Giovanni Medici
Rep Power: 12 |
First of all thanks to all developers for another interesting update of SU2.
I was giving a try to one of the new experimental features introduced, AUSM+M, and but SU2 exits in the initialization with an error : Code:
Error in "void CDriver::Numerics_Preprocessing(CConfig*, CGeometry**, CSolver***, CNumerics****&) const": ------------------------------------------------------------------------- Invalid upwind scheme or not implemented. ------------------------------ Error Exit ------------------------------- Any clue on what I'm missing? Below you can find the cfg file. Thanks a lot! Code:
% ------------- DIRECT, ADJOINT, AND LINEARIZED PROBLEM DEFINITION ------------% % % Physical governing equations (EULER, NAVIER_STOKES, % WAVE_EQUATION, HEAT_EQUATION, FEM_ELASTICITY, % POISSON_EQUATION, NEMO_NAVIER_STOKES) SOLVER= EULER % % MATH_PROBLEM= DIRECT RESTART_SOL= NO % AXISYMMETRIC= YES % ----------- COMPRESSIBLE AND INCOMPRESSIBLE FREE-STREAM DEFINITION ----------% % % Mach number (non-dimensional, based on the free-stream values) MACH_NUMBER= 5 % % Angle of attack (degrees, only for compressible flows) AOA= 0.0 % % Side-slip angle (degrees, only for compressible flows) SIDESLIP_ANGLE= 0.0 % % Init option to choose between Reynolds (default) or thermodynamics quantities % for initializing the solution (REYNOLDS, TD_CONDITIONS) % INIT_OPTION= REYNOLDS % % Free-stream option to choose between density and temperature (default) for % initializing the solution (TEMPERATURE_FS, DENSITY_FS) FREESTREAM_OPTION= TEMPERATURE_FS % % Free-stream temperature (288.15 K by default) FREESTREAM_TEMPERATURE= 270.65 % %FREESTREAM_TEMPERATURE_VE= 270.65 % % Free-stream pressure (101325.0 N/m^2 by default) FREESTREAM_PRESSURE= 670.79 % % Reynolds number (non-dimensional, based on the free-stream values) %REYNOLDS_NUMBER= 10000 KIND_TURB_MODEL= NONE % ---- IDEAL GAS, POLYTROPIC, VAN DER WAALS AND PENG ROBINSON CONSTANTS -------% % % Different gas model (STANDARD_AIR, IDEAL_GAS, VW_GAS, PR_GAS, MUTATIONPP SU2_NONEQ) FLUID_MODEL= STANDARD_AIR % ---------------------- REFERENCE VALUE DEFINITION ---------------------------% % % Reference origin for moment computation REF_ORIGIN_MOMENT_X = 0.00 REF_ORIGIN_MOMENT_Y = 0.00 REF_ORIGIN_MOMENT_Z = 0.00 % % % Compressible flow non-dimensionalization (DIMENSIONAL, FREESTREAM_PRESS_EQ_ONE, % FREESTREAM_VEL_EQ_MACH, FREESTREAM_VEL_EQ_ONE) REF_DIMENSIONALIZATION= FREESTREAM_VEL_EQ_ONE % -------------------- BOUNDARY CONDITION DEFINITION --------------------------% % MARKER_EULER= ( Body, Back ) MARKER_OUTLET= ( Outlet, 670.79 ) MARKER_SUPERSONIC_INLET= ( Inlet, 270.65, 670.79, 1649.01 , 0, 0) MARKER_PLOTTING= (Body, Back ) MARKER_MONITORING= (Body, Back ) MARKER_SYM = ( Symmetry ) % ------------- COMMON PARAMETERS DEFINING THE NUMERICAL METHOD ---------------% % % Numerical method for spatial gradients (GREEN_GAUSS, WEIGHTED_LEAST_SQUARES) NUM_METHOD_GRAD= GREEN_GAUSS CFL_NUMBER= 0.5 % Adaptive CFL number (NO, YES) CFL_ADAPT= NO % % Parameters of the adaptive CFL number (factor-down, factor-up, CFL min value, % CFL max value, acceptable linear solver convergence) % Local CFL increases by factor-up until max if the solution rate of change is not limited, % and acceptable linear convergence is achieved. It is reduced if rate is limited, or if there % is not enough linear convergence, or if the nonlinear residuals are stagnant and oscillatory. % It is reset back to min when linear solvers diverge, or if nonlinear residuals increase too much. CFL_ADAPT_PARAM= ( 0.1, 2.0, 10.0, 1e10, 0.001 ) % Number of total iterations ITER= 500000 % % ----------------------- SLOPE LIMITER DEFINITION ----------------------------% % % Coefficient for the limiter VENKAT_LIMITER_COEFF= 0.05 % % Coefficient for the sharp edges limiter ADJ_SHARP_LIMITER_COEFF= 3.0 % % Reference coefficient (sensitivity) for detecting sharp edges. REF_SHARP_EDGES= 3.0 % % Remove sharp edges from the sensitivity evaluation (NO, YES) SENS_REMOVE_SHARP= NO % ------------------------ LINEAR SOLVER DEFINITION ---------------------------% % LINEAR_SOLVER= BCGSTAB LINEAR_SOLVER_ERROR= 1E-6 LINEAR_SOLVER_ITER= 5 % -------------------- FLOW NUMERICAL METHOD DEFINITION -----------------------% % % Convective numerical method (JST, LAX-FRIEDRICH, CUSP, ROE, AUSM, HLLC, % TURKEL_PREC, MSW) CONV_NUM_METHOD_FLOW= AUSMPLUSM % Spatial numerical order integration (1ST_ORDER, 2ND_ORDER, 2ND_ORDER_LIMITER) MUSCL_FLOW= NO % Slope limiter (NONE, VENKATAKRISHNAN, VENKATAKRISHNAN_WANG, % BARTH_JESPERSEN, VAN_ALBADA_EDGE) SLOPE_LIMITER_FLOW= VAN_ALBADA_EDGE %VENKAT_LIMITER_COEFF= 0.05 TIME_DISCRE_FLOW= EULER_EXPLICIT % --------------------------- CONVERGENCE PARAMETERS --------------------------% % CONV_RESIDUAL_MINVAL= -15 CONV_STARTITER= 10 % ------------------------- INPUT/OUTPUT INFORMATION --------------------------% % MESH_FILENAME= Mesh.su2 MESH_FORMAT= SU2 SOLUTION_FILENAME= restart_flow.dat TABULAR_FORMAT= CSV CONV_FILENAME= convergence RESTART_FILENAME= restart_flow.dat VOLUME_FILENAME= soln_volume SURFACE_FILENAME= soln_surface OUTPUT_WRT_FREQ= 5000 SCREEN_OUTPUT= (INNER_ITER, RMS_DENSITY_0, RMS_DENSITY_1, RMS_DENSITY_2, RMS_DENSITY_3, RMS_DENSITY_4, RMS_ENERGY, RMS_ENERGY_VE, LIFT, DRAG, TOTAL_HEATFLUX) HISTORY_OUTPUT= (ITER, RMS_RES, AERO_COEFF) OUTPUT_FILES= (RESTART, PARAVIEW, SURFACE_PARAVIEW) |
February 7, 2023, 13:22 |
#2 | |
bigfoot
For setups, you can start with the regression testcases that come with SU2. The ausm test cases are here: https://github.com/su2code/SU2/tree/...brium/invwedge meshes are here: https://github.com/su2code/TestCases...brium/invwedge |
February 7, 2023, 14:22 |
Giovanni Medici
Rep Power: 12 |
Oh yeah, thank you @bigfootedrockmidget, you are right, in the github post referenced in the release notes (https://github.com/su2code/SU2/pull/1773), there are indeed, as validation transational-rotational, and vibrational-electronic temperatures!
I should have thought about that! |
February 8, 2023, 08:43 |
Wally Maier
Rep Power: 7 |
As @bigfootedrockmidget mentioned, AUSM+M is only available as a NEMO feature. However, I expected that the implementation for an ideal gas would be straight-forward! This is my plug to grab developers |
Upwind scheme for INC_RANS does not converge | jw-89 | SU2 | 3 | December 4, 2021 00:40 |
long error when using make-install SU2_AD. | tomp1993 | SU2 Installation | 3 | March 17, 2018 06:25 |
parallel simulations - error message: "OPT_ITERATIONS: invalid option name" | v8areu | SU2 | 5 | July 23, 2015 02:57 |
OpenFOAM install on Ubuntu Natty 11.04 | bkubicek | OpenFOAM | 13 | May 26, 2011 05:48 |
Help!explicit multistage scheme with upwind scheme | D .T. | Main CFD Forum | 1 | June 4, 2003 03:42 |
