February 22, 2023, 18:11 |
su2 would not start iterating
Zida
Rep Power: 3 |
I'm trying to run a 3D incompressible eulers simulation using SU2 (Version 7.5.0 "Blackbird"), the case is basically an umbrella canopy embedded in a simple box mesh, subjected to 8m/s freestream. The solver simply won't start iterating, it does not print any error message but I think the problem could be: "WARNING: SURFACE_PRESSURE_DROP can only be computed for at least 2 surfaces (outlet, inlet, ...)" Any help would be appreciated. |
February 23, 2023, 00:52 |
Pedro Gomes
Rep Power: 13 |
That is not the issue. Can you upload your config? Or reproduce the problem with a smaller mesh? (check your system monitor maybe you are running out of memory)
Are you running with MPI? On linux or windows? etc. etc. more detail please |
February 23, 2023, 05:52 |
#3 | |
Zida
Rep Power: 3 |
Here's my config and .geo file, (.su2 mesh too large to upload) The config file I'm using is basically the one in the incompressible hydrofoil tutorial, left it mostly unchanged because I just wanted to test things. (This is my first CFD experience) And I made my mesh with Gmsh. Thanks. |
February 23, 2023, 08:59 |
bigfoot
Rep Power: 17 |
Do the SU2 tutorial cases run for you?
February 25, 2023, 20:21 |
Pedro Gomes
Rep Power: 13 |
I tried it now, opened the geo in gmsh, clicked 3D Mesh and exported as SU2 (do not select export all elements).
The solver started fine, it uses about 3.2GB of RAM so that's probably not the issue. I don't know much about running SU2 on windows but check if you are not on a system folder (or protected some other way). If you open task manager is SU2 using any CPU while it is stuck? |
February 27, 2023, 05:53 |
Zida
Rep Power: 3 |
Yes they all work, tutorials and test cases
February 27, 2023, 06:07 |
Zida
Rep Power: 3 |
Still can't get the solver to start.
It's definitely not an memory issue, I've tried smaller meshes, same problem. It doesn't seem su2 uses any CPU while it's stuck :/ All my executables are in C:\CFD\bin\SU2, and I created sub directories in CFD for all my runs |
February 27, 2023, 06:28 |
#8 | |
Zida
Rep Power: 3 |
Any idea where I screwed up? Many thanks for all your help. |
February 27, 2023, 06:32 |
#9 | |
Zida
Rep Power: 3 |
"segmentation fault: 11" at the end, So this could be a security related problem the whole time? |
TimeVaryingMappedFixedValue | irishdave | OpenFOAM Running, Solving & CFD | 32 | June 16, 2021 06:55 |
Introducing SU2 International Developers Society (IDS) | fpalacios | SU2 News & Announcements | 1 | June 17, 2019 22:38 |
SU2 process was terminated by signal '11' | tomp1993 | SU2 Shape Design | 5 | March 1, 2018 04:32 |
best setting for SU2 | mechy | SU2 | 3 | April 20, 2014 19:13 |
Official release of SU2 V3.0 and SU2 Educational V1.0 | fpalacios | SU2 News & Announcements | 2 | January 22, 2014 05:28 |
