Drean
Rep Power: 3 ![]() |
This might be trivial for you all. Can someone explain surface sensitivity map after continuous adjoint calculation? Does higher surface sensitivity magnitude means node at that point should curve outward?
bigfoot
Rep Power: 17 ![]() |
Here are some nice illustrations of what surface sensitivities mean:
https://su2code.github.io/tutorials/Static_CHT/ They are basically vectors pointing in the direction that will minimize the objective if you move the node connected to that vector. If the magnitude of the vector is larger, then the movement of this node will have a larger impact on the objective compared to nodes that have smaller magnitude vectors, so you move the nodes a distance according to the (relative) magnitude of the vectors. |
su2, surface sensitivity |
Parametric surface deformations for optimization | tomp1993 | SU2 Shape Design | 5 | January 19, 2024 11:25 |
How is the continuous adjoint surface sensitivity defined? | lalatuobu | SU2 | 0 | March 11, 2022 14:36 |
Surface sensitivity projection onto custom made design variables | JanH | SU2 | 1 | May 12, 2015 16:47 |
About Surface Sensitivity computation | Tommy Chen | SU2 | 1 | March 10, 2014 16:14 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
