Modeling Counter-Rotating Propellers with the Actuator Disk Model in SU2 |
September 19, 2023, 00:30 |
M Kaushik Reddy
I've been trying to set up a case (with a code of my own) which makes use of the actuator disk model from SU2 (general momentum theory). There are two propellers on the aircraft, one on each wing (left + right). The propellers are counter-rotating. So far, I've been able to run simulations where the propellers are co-rotating, but I'm unable to figure out the way to reverse the direction of rotation without also reversing the axial pressure difference that manifests. I've made use of the OptimalPropeller.py script (https://github.com/su2code/SU2/blob/...alPropeller.py) in order to generate ActuatorDisk.dat (the input datafile). Please let me know if anybody has any insights on this or has faced a similar issue, thanks! |
February 8, 2024, 11:15 |
chang xu
Rep Power: 2 |
I am also facing the same issue, have you already resolved this problem? Thanks in advance! |
actuator disk, cfd, counter rotating, propeller, wings |
Car external aerodynamic with wheel spinning issue | hokhay | FloEFD, FloWorks & FloTHERM | 2 | August 18, 2016 04:23 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
FSI on a Rotating Structural Model | drgolf | CFX | 9 | August 30, 2007 12:08 |
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model | Jonas Larsson | FLUENT | 5 | March 13, 2000 03:27 |
