Zhang
Rep Power: 3 ![]() |
Dear all,
I want to get the TKE and DISSIPATION in volume output to estimate my mesh if works well in LES. I first use the SA model, but it doesn't output TKE and DISSIPATION directly, so I change the SST model, and run SU2_CFD -d <>.cfg to ensure the volume output obtain them. BUT it only has TKE only, I didn't see the dissipation in it. So how can I get the dissipation distribution in my flow field? Any help is necessary for me! Thanks for your patience. Yours, Zhang |
bigfoot
Rep Power: 17 ![]() |
The turbulence dissipation is called "Omega" in the k-omega model. And yes, the SA model cannot give you the tke and dissipation because they are not solved for. Instead, you have the turbulent viscosity Nu_t.
Zhang
Thank you so much. You've been very helpfu
Foam::error::printStack(Foam::Ostream&) in compressibleInterFoam | JM27 | OpenFOAM Running, Solving & CFD | 2 | May 26, 2020 08:13 |
[blockMesh] edges not aligned with or perpendicular to non-empty directions | ynos | OpenFOAM Meshing & Mesh Conversion | 6 | March 26, 2020 15:02 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
average weighted area of volume fraction at output | umar959 | Main CFD Forum | 0 | January 20, 2012 02:47 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
