December 6, 2023, 09:03 |
I have a problem in restart_flow.dat
David wang
Rep Power: 2 |
I encountered the following error while working on the "Constrained shape design of a transient turbine air at a cte. CL" case. I tried opening restart_ Flow.dat file, but cannot be opened.
error: Reading and storing the solution from restart_flow. Error in "virtual void CBaselineOutput::SetVolumeOutputFields(CConfig*)": ------------------------------------------------------------------------- No coordinates found in the restart file!! ------------------------------ Error Exit ------------------------------- 18042 triangles. 4800 quadrilaterals. 4800 quadrilaterals. 18042 triangles. 4800 quadrilaterals. Identify vertices. Storing a mapping from global to local point index. Identify vertices. Storing a mapping from global to local point index. ------------------------- Solution Postprocessing ----------------------- Reading and storing the solution from restart_flow. Error in "virtual void CBaselineOutput::SetVolumeOutputFields(CConfig*)": ------------------------------------------------------------------------- No coordinates found in the restart file!! ------------------------------ Error Exit ------------------------------- ------------------------- Solution Postprocessing ----------------------- Reading and storing the solution from restart_flow. Error in "virtual void CBaselineOutput::SetVolumeOutputFields(CConfig*)": ------------------------------------------------------------------------- No coordinates found in the restart file!! ------------------------------ Error Exit ------------------------------- Identify vertices. Storing a mapping from global to local point index. Error in "virtual void CBaselineOutput::SetVolumeOutputFields(CConfig*)": ------------------------------------------------------------------------- No coordinates found in the restart file!! ------------------------------ Error Exit ------------------------------- ------------------------- Solution Postprocessing ----------------------- Reading and storing the solution from restart_flow. Error in "virtual void CBaselineOutput::SetVolumeOutputFields(CConfig*)": ------------------------------------------------------------------------- No coordinates found in the restart file!! ------------------------------ Error Exit ------------------------------- Identify vertices. Storing a mapping from global to local point index. ------------------------- Solution Postprocessing ----------------------- Reading and storing the solution from restart_flow. Error in "virtual void CBaselineOutput::SetVolumeOutputFields(CConfig*)": ------------------------------------------------------------------------- No coordinates found in the restart file!! ------------------------------ Error Exit ------------------------------- 18042 triangles. 4800 quadrilaterals. Identify vertices. Storing a mapping from global to local point index. ------------------------- Solution Postprocessing ----------------------- Reading and storing the solution from restart_flow. Error in "virtual void CBaselineOutput::SetVolumeOutputFields(CConfig*)": ------------------------------------------------------------------------- No coordinates found in the restart file!! ------------------------------ Error Exit ------------------------------- |
December 6, 2023, 09:07 |
David wang
Rep Power: 2 |
my Ubuntu can't open ".dat" file. I don't know why?
When I tried to open the. dat file, it said "Could Not Display solution flow. dat The file is of an unknown type” |
December 6, 2023, 10:29 |
bigfoot
Rep Power: 17 |
Do you have the files for us to reproduce this issue?
March 1, 2024, 22:12 |
I have the same problem as Wang
#4 | |
Tongtong
Rep Power: 2 |
I am encountering the same issue as Wang Dawei when attempting to run the SU2 official case "Constrained shape design of a transonic turbulent airfoil at a constant CL" (https://su2code.github.io/tutorials/...ained_RAE2822/) using SU2 version 8.0.0. I am operating on the WSL Ubuntu-22.04 platform. In the attachments, I will provide the log files. I seek your assistance in resolving this matter. |
su2 8.0.0 |
SU2-7.0.1 on ubuntu 18.04 | hyunko | SU2 Installation | 7 | March 16, 2020 04:37 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
