April 16, 2024, 10:30 |
Segfault writing restart files
Tim
Rep Power: 9 |
I am running a case which otherwise seems to run fine. However, when writing restart files it segfaults only if there is already an existing restart file.
So if my OUTPUT_WRT_FREQ is less than my ITER, it will segfault on the second write, or at the completion of a successful run when the final solution is written to disk. Also if I try to restart a solution, it will obviously segfault when trying to write the new solution. I'm running version 8.0.1. Note the first write of the of the restart file works fine. Any ideas? Here is a partial trace: Code:
+-----------------------------------------------------------------------+ | File Writing Summary | Filename | +-----------------------------------------------------------------------+ |SU2 binary restart |restart_flow.dat | [<> :0:6905] Caught signal 11 (Segmentation fault: address not mapped to object at address 0x30) Code:
==== backtrace (tid: 7130) ==== 0 0x000000000004eb50 killpg() ???:0 1 0x0000000000049f61 opal_obj_run_destructors() /build-result/src/hpcx-v2.16-gcc-mlnx_ofed-redhat8-cuda12-gdrcopy2-nccl2.18-x86_64/ompi-db10576f403e833fdf7cd0d938e66b8393b20680/ 2 0x0000000000049f61 ompi_file_close() /build-result/src/hpcx-v2.16-gcc-mlnx_ofed-redhat8-cuda12-gdrcopy2-nccl2.18-x86_64/ompi-db10576f403e833fdf7cd0d938e66b8393b20680/ompi/file 3 0x000000000006efe6 PMPI_File_close() /build-result/src/hpcx-v2.16-gcc-mlnx_ofed-redhat8-cuda12-gdrcopy2-nccl2.18-x86_64/ompi-db10576f403e833fdf7cd0d938e66b8393b20680/ompi/mpi/ 4 0x00000000005e8a58 CFileWriter::OpenMPIFile() ???:0 5 0x00000000005f8a5e CSU2BinaryFileWriter::WriteData() ???:0 6 0x00000000005c3391 COutput::WriteToFile() ???:0 7 0x00000000005c4d36 COutput::SetResultFiles() ???:0 8 0x000000000052de76 CFluidIteration::Solve() ???:0 9 0x0000000000505fd0 CSinglezoneDriver::StartSolver() ???:0 10 0x000000000047b8d8 main() ???:0 11 0x000000000003ad85 __libc_start_main() ???:0 12 0x00000000004a1b1e _start() ???:0 Code:
================================= [:07130] *** Process received signal *** [:07130] Signal: Segmentation fault (11) [:07130] Signal code: (-6) [:07130] Failing at address: 0x4e2100001bda [:07130] [ 0] /usr/lib64/libc.so.6(+0x4eb50)[0x14c9a1b0cb50] [:07130] [ 1] /opt/hpcx-v2.16-gcc-mlnx_ofed-redhat8-cuda12-gdrcopy2-nccl2.18-x86_64/ompi/lib/libmpi.so.40(ompi_file_close+0x11)[0x14c9a27fbf61] [:07130] [ 2] /opt/hpcx-v2.16-gcc-mlnx_ofed-redhat8-cuda12-gdrcopy2-nccl2.18-x86_64/ompi/lib/libmpi.so.40(PMPI_File_close+0x16)[0x14c9a2820fe6] [:07130] [ 3] /opt/su2/su2-8.0.1/bin/SU2_CFD[0x5e8a58] [:07130] [ 4] /opt/su2/su2-8.0.1/bin/SU2_CFD[0x5f8a5e] [:07130] [ 5] /opt/su2/su2-8.0.1/bin/SU2_CFD[0x5c3391] [:07130] [ 6] /opt/su2/su2-8.0.1/bin/SU2_CFD[0x5c4d36] [:07130] [ 7] /opt/su2/su2-8.0.1/bin/SU2_CFD[0x52de76] [:07130] [ 8] /opt/su2/su2-8.0.1/bin/SU2_CFD[0x505fd0] [:07130] [ 9] /opt/su2/su2-8.0.1/bin/SU2_CFD[0x47b8d8] [:07130] [10] /usr/lib64/libc.so.6(__libc_start_main+0xe5)[0x14c9a1af8d85] [:07130] [11] /opt/su2/su2-8.0.1/bin/SU2_CFD[0x4a1b1e] [:07130] *** End of error message *** |
April 16, 2024, 13:31 |
bigfoot
Rep Power: 17 |
Does this only happen when using mpi?
Merging history files with restart case | shahidkhan | SU2 | 2 | February 13, 2022 23:48 |
Time-accurate solution restart from steady state solution | jyotir | SU2 | 6 | December 8, 2021 08:34 |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 11:04 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
Results saving in CFD | hawk | Main CFD Forum | 16 | July 21, 2005 20:51 |
