Home > Forums > General Forums > System Analysis
All effects to consider in high pressure water flowing in thin sections
Old   September 20, 2016, 12:13
Exclamation All effects to consider in high pressure water flowing in thin sections
power
enginpower is on a distinguished road
Hi all,
I'm studying a flow of water through a pipe where in some points the section area is very very small. All the pipe is long almost one meter, on the inlet section there is a pressure of 25bar and at the outlet section the pression drops to 1bar (atmospheric pressure). The pipe has a very strange shape, almost due to some control devices, so that in some points the section is almost like an annulus, but with the circles not concentric. In these points the minimum difference between the rays is almost 0.02 mm (2*10^-5m), while the inlet and outlet sections have an averaged diameter of 8cm (8*10^-2 m).
I need to simulate the entire flow in the pipe with a CFD software, but before I need to understand which phenomena occur, to take in consideration for the CFD simulations.
Obviously I thought to cavitation.
But because a very accurate mesh is necessary around the restriction, which requires so much memory, I would like to share with you suggestions for an accurate analysis, about the following questions.
How to consider the surface forces on the fluid, where the thin between the walls are only 0.02mm? What if fluid is gas? What if fluid is liquid? Do you know similar problems in literature to be useful to solve these fluid dynamics problems?
Thanks
enginpower is offline   Reply With Quote
cavitation bubble, thin channel, thin film flows
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
BC for Actuator Disk - Flow Vel from High Pressure to Low Pressure vinguva OpenFOAM Running, Solving & CFD 2 March 7, 2016 23:46
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 07:10
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
