With position variable source term discretization |
Rep Power: 0 ![]() |
If the heat generation varies linearly with position. How can i discretize that?
Problem is 1D mixed of convection and conduction. ![]() |
#2 | |
Rami Ben-Zvi
Rep Power: 18 ![]() |
It is quite simple with the FEM. See e.g., my paper R. Ben-Zvi, H. Scher and B. Berkowitz, Two-dimensional finite element method solution of a class of integro-differential equations: Application to non-Fickian transport in disordered media, IJNME, Vol. 112 No. 5, pp. 459-478, 2017, DOI: 10.1002/nme.5524, 2017.in which you may drop the transient and the memory terms and insert S=Axi + B. I hope it helps, Rami |
Rep Power: 9 ![]() |
Hello Amirhossein,
I think you can use a linear equation, e.g. q = Ax + B where A and B are coefficients and x is the distance from your reference point. One way of discretization that came to my mind first is setting a do or for loop starting at your reference point and then incrementing. Assign q = B at x=0 assuming 0 is your reference position and B is the heat generation at that point. Then, since you know your final length (xmax) for nmax stepsizes you would have dx = xmax/nmax. Then it is, q = q + A*dx for all the remaining stepsizes. Regards, Lejonet |
Display Modes | |
momentum source term | zwdi | FLUENT | 14 | June 27, 2017 15:40 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
Help for the small implementation in turbulence model | shipman | OpenFOAM Programming & Development | 25 | March 19, 2014 10:08 |
[swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 13:59 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
