August 29, 2017, 09:53 |
solving heat PDE using FFCT
Aows
the problem is
solve the following heat problem using FFCT: A metal bar of length L, is at constant temperature of [tex]U_0[/tex], at t=0 the end x=L is suddenly given the constant temperature of [tex]U_1[/tex] and the end x=0 is insulated. Assuming that the surface of the bar is insulated, find the temperature at any point x of the bar at any time t>0, assume k=1 Equations used: heat eq. [tex]\dfrac{\partial^2 u}{\partial x^2} = \dfrac{1}{k} \dfrac{\partial u}{\partial t}[/tex] with the additional equations shown on the attached image. my attempt: my attempt goes like this: $$ \frac {\partial^2 u} {\partial x^2} = \frac 1 k \frac {\partial u} {\partial t} $$ [tex]\mathcal{F}_{fc} \left[ \dfrac {\partial u} {\partial t} \right] = \mathcal{F}_{fc} \dfrac {\partial^2 u} {\partial x^2}[/tex] [tex]\dfrac {dU} {dt} = {-\left( \dfrac {{n} {\pi}} L \right)}^{2} * F(x,t) + \left( {-1} \right)^n \dfrac {\partial{f(L,t)}} {\partial x} - \dfrac {\partial{f(0,t)}} {\partial x}[/tex] [tex]\dfrac {dU} {dt} = - \left( \dfrac {{n} {\pi}} L \right)^2 * F(x,t) + \left( {-1} \right)^n \dfrac {\partial{f(L,t)}} {\partial x}[/tex] and i dont know how to continue... the attached Image: FFCT.jpg Last edited by aows61; August 29, 2017 at 09:57. Reason: syntax correcting |
differentialequation, fouriertransform, heatequation |
problem with Min/max rho | tH3f0rC3 | OpenFOAM | 8 | July 31, 2019 09:48 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 06:37 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 03:34 |
Error while running rhoPisoFoam.. | nileshjrane | OpenFOAM Running, Solving & CFD | 8 | August 26, 2010 12:50 |
