Home > Forums > General Forums > System Analysis
cooling of a hot porous zone.
Old   April 17, 2018, 10:11
Default cooling of a hot porous zone.
anonymous
asda3D is on a distinguished road
Hi everyone. I have managed to simulate a porous zone in CFD to simulate a hot powder bed. I would like to set its temp to 450k and measure the cooling effect of air flowing through it. I am not sure on how to go about doing this and would like to know if it even possible. Thanks for any feedback.
asda3D is offline   Reply With Quote
Old   April 22, 2018, 15:08
Default porous media set up
mishal
Muhammad Shad is on a distinguished road
Send a message via Skype™ to Muhammad Shad
can you specify the inlet temperature of Air, temperature of porous media, material of porous structure so that you question becomes clear for understanding. thank you
Muhammad Shad is offline   Reply With Quote
Old   April 23, 2018, 02:27
Default Porous conditions
anonymous
Thank your for the reply.
The inlet air is at standard room temp (roughly 298k). The air then travels through the pipe and reaches a porous zone. The porous medium is made up of nylon 12 (porosity 0.035) and its at an elevated temp of 450K.
Currently I am able to simulate the porous zone via fluent, by setting it as a fluid zone and ticking the porous zone sub classification. I am just finding it difficult to set the temp of the nylon bed to 450K and measure the heat transfer.
Hope this has clarified my problem. Again, any help is much appreciated
Modelling Combustion in Porous Zone tanjinjack FLUENT 2 September 26, 2016 04:10
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 09:28
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 10:52
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 17:51
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 01:08
