Home > Forums > General Forums > System Analysis
High outlet temperatures with laminar flow
Old   October 23, 2018, 04:02
Default High outlet temperatures with laminar flow
Vestdam
Vestdam is on a distinguished road
Hi there!
I am modelling a simple geometry, where a pipe is heated with a constant heat flux and fluid (water) is flowing in the pipe.
When I model turbulent flow, the outlet temperature of the fluid corresponds to the amout of heat supplied to the pipe.
However, when I model laminar flow (no turbulence model) the outlet temperatures are too high. I get 20% more energy increase of the fluid than what is supplied to the pipe.
I extract the temperature and velocity as an area weighted average at an extended outlet and take the average density and heat capacity of the fluid. The inlet temperature is constant with a velocity inlet boundary condition. The outlet is fixed pressure and pipe is insulated where it is not supplied with heat from the constant heat flux.
Could this be caused by the way I extract the temperature? Could it have something to do with the length of the extended outlet?
Vestdam is offline   Reply With Quote
Laminar flow and wall roughness junbbung FLUENT 2 November 26, 2022 21:22
CFDesign V11 -- Reverse flow at outlet maruthiv Autodesk Simulation CFD 1 June 17, 2011 09:38
how to solve a problem involving both laminar and turbulent flow seefd FLUENT 1 June 3, 2011 03:20
Pressure driven laminar flow simpleFoam pressure higher at the outlet than inlet gabriel OpenFOAM Running, Solving & CFD 16 September 30, 2009 18:20
VOF Outlet boundary condition in cfd - ace JM Main CFD Forum 0 December 15, 2006 08:07
