Jedidi
Rep Power: 7 ![]() |
hi guys, i want to do 2-way -coupling system (using transient structural- fluent)
in the input there's a pressure that increase little by little and attend 400000 pa in reality it's supposed , that the fluid pushs the piston (whish have a stifness and a preload) so i put layering method , and system coupling in output of fluid (which i define as a wall) should i active 1dof to make wall able to translate ? i appreciate your help |
ANGELO
Rep Power: 6 ![]() |
I am working on a project using Static acoustic of Ansys. I have A disk with a shaft(solid domain-Steel) and a cylindrical fluid domain(Air or water). I defined my acoustic region as the cylindrical fluid and my structural region as the disk with the shaft and then I try to apply a force on the disk surface, and it doesn't work saying that ''This structural load should be defined on structural region'' although the disk is defined as structural region. I tried to apply loads on the same disk before and it worked very well. You can see the photo attached. I appreciate your help Thanks, Angelo |
Display Modes | |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
FSI: Pressure and Normal Force don't match with expected values | Geraud | CFX | 6 | August 21, 2012 15:34 |
My Revised "Time Vs Energy" Article For Review | Abhi | Main CFD Forum | 2 | July 9, 2002 09:08 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
