Ibi
Rep Power: 0 ![]() |
Good morning all,
1. Using transient thermal analysis in ANSYS, I am trying to use an air ambient temperature of -10 degree Celsius to freeze an alum sludge with an initial temperature of 11.6 degree celsius. 2. I have solve the physics but the achieved result on the gradient plot is showing that I am using the alum sludge to cool with air. which is not what I expected. 3. I expected my refrigerant chamber with an ambient negative value of -10 degree Celsius to be on permanent blue and the alum sludge on red because I am using an ambient temp of -10 to cool down an initial temperature of 11 degree Celsius. Please see the attached schematic 2D description. I will appreciate hearing from you. Thank You Ibi |
Erik
Rep Power: 21 ![]() |
Sound like you have something wrong in your setup, which is difficult for us to diagnose.
First off, how did you set initial conditions for temperature of each body? |
Ibi
Thank you for getting back to me. I selected my mud tray and the refrigerant chamber together for the convection boundary condition and the mud tray alone for the temperature since I am using a negative ambient temperature to freeze the initial temperature of my mud. I think having a separate convection BC for the cooling refrigerant and mud might help with assigning a different temperature BC for them and creating a negative heat flux since I want to remove heat from the mud to make it freeze. I await your response. Thanks |
Display Modes | |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
rhoCentralFoam Negative initial temperature in simulation of gas jet into vacuum | c_underwood | OpenFOAM Running, Solving & CFD | 1 | November 19, 2020 14:45 |
Negative temperature T0 in sonicFoam OF 5.x | deepbandivadekar | OpenFOAM Running, Solving & CFD | 8 | August 20, 2018 09:40 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
