Home > Forums > General Forums > System Analysis
Solution of the 1D heat equation in cylindrical co-ordinates
Old   March 25, 2022, 05:14
Default Solution of the 1D heat equation in cylindrical co-ordinates
Matthew
hunt_mat is on a distinguished road
I am trying to solve the transient heat equation in cylindrical co-ordinates using finite differences and the Crank-Nicholson method. The problem I am having is that I cannot seem to get the inner boundary condition, which is the usual no-flux condition to work in my code. The heat drops at both the centre and the outer edge, this is clearly unphysical but I don't know what's going on. I tried the same method to solve the spherical case and it worked perfectly. Can someone tell me what I'm doing wrong or is it simply not possible to solve the heat equation in cylindrical co-ordinates using finite differences?
I have attached my derivation of the method.
hunt_mat is offline   Reply With Quote
Coupled Heat and Mass Transfer Mecroob OpenFOAM Running, Solving & CFD 1 July 12, 2020 19:24
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 75 August 20, 2018 05:37
Unsteady Cylindrical heat equation with no source abhi084 Main CFD Forum 6 July 9, 2016 02:37
Heat Exchanger Simulation_Not getting desired solution Kashif Rashid FLUENT 0 May 4, 2014 02:41
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
