1D simulation diffusion term, polar coordinates, moving boundary condition |
Andrea
Rep Power: 4 ![]() |
I am trying to integrate the system I am showing in the page 3 of the attached pdf but I am having some problems with Cw and the radius because they should reach a minimum and a maximum respectively but in my simulation they go towards +inf and -inf, and Cw is decreasing too fast. Cw0, K, Cm are parameters, I also attach the whole paper if something is not clear enough. (I am using matlab). I am using forward euler and finite difference method. It is probably better to integrate with a variable space step but I cant figure out how to do it, so I just made a big enough domain to allow the radius to increase. I have started recently cfd so be kind ahahah.
![]() Code:
clc; clear all; close all %% DATA K = 1; Diff = 4e-9; Cw0 = 55e-3; %mol/m3 r0 = 1e-3; L = 12e-3; N = 500; tf = 150; Cm = 30e-3; %mol/m3 Cinf = 0; %% preprocessing h = L/N; grid1D = linspace(0,L,N+1); %% SOLUTION index = find(grid1D >= r0); dt = 0.005; tsteps = tf/dt; %initial sol C = [Cw0.*ones(1,index(1)-1)./K,Cm*ones(1,index(end)-index(1))]'; %mem allocation for plot Cplot = zeros(size(grid1D)); %loop for t = 1:tsteps C0 = C; % bc 6: eq 6 integration if t ~= 1 indexrd = find(grid1D >= rd); for counter_bc6 = index(1):indexrd(1) - 1 int6(counter_bc6) = (-4*pi*C(counter_bc6)*grid1D(counter_bc6)^2 -4*pi*C(counter_bc6 + 1)*grid1D(counter_bc6+1)^2)*h/2; end Cw = sum(int6)/(4/3*pi*r0^3) + Cw0; else Cw = Cw0; end % eq 3 C(index(1)) = Cw/K; % eq 5 if t == 1 rd = r0 + h; else d = -Cm + 8*Cm -8*C(indexrd(1)- 2) + C(indexrd(1)- 3); rd = -Diff*(d)/12/h/Cm*dt + rd; end if (mod(rd,h)~=0) rd = rd + (h - mod(rd,h)); end %eq 4 indexrd_new = find(grid1D>=rd); %expl for i = index(1):N-1 C(i) = C0(i) + dt*(Diff/h^2*(C0(i+1) + C0(i-1) - 2*C0(i)) + 2*Diff/i/h*(C0(i+1)-C0(i-1))/h ); end for i = indexrd_new(1) :length(C) C(i) = Cm; end for i = 1:index C(i) = Cw; end if (mod(t,100)==0) % => Every 50 time steps for i=1:N-1 Cplot(i) = 0.5*(C(i+1) + C(i)); end plot(grid1D,Cplot); hold on plot(grid1D(indexrd_new(1))*ones(2,1),[0.028 0.052]) %scatter(t*dt,Cw) hold off ylim([2.8e-2 5.2e-2]) xlim([0 L/2]) xlabel("length [m]") ylabel("Concentration [mol/m3]") message = sprintf('t=%d', ceil(t*dt)); time = annotation('textbox',[0.15 0.8 0.1 0.1],'String',message,'EdgeColor','k','BackgroundColor','w'); drawnow; end end |
Matthew
Rep Power: 5 ![]() |
The way to include Neumann boundary conditions into the diffusion is to use ghost cells at each point. You can then correctly fit in the ghost points that you get from the basic finite difference, that's how you do this normally. You have a moving boundary condition, so what you could do is fix the boundary with the transformation:
r is mapped to r/R(t), then this fixes the boundary. The resulting equations you get will be a coupled set of equations for the nodes and the moving boundary. You can then use Newton-Raphson to solve these equations if they're nonlinear, or a matrix method if they're linear. |
Display Modes | |
Wind tunnel flow simulation boundary condition issue | charan3007 | SU2 | 0 | October 21, 2021 09:27 |
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 17, 2020 00:44 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 08:30 |
My radial inflow turbine | Abo Anas | CFX | 27 | May 11, 2018 02:44 |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 19:02 |
