Home > Forums > Visualization & Post-Processing Software > Tecplot
To plot velocity profile along different x-axis
Old   June 26, 2013, 13:16
Question To plot velocity profile along different x-axis
Dinesh Babu
devanson is on a distinguished road
Send a message via AIM to devanson Send a message via MSN to devanson Send a message via Yahoo to devanson Send a message via Skype™ to devanson
need help urgently. As said in title, i want to plot velocity profile at different x-axis position in tecplot. is it possible to do in fluent 13 itself?
devanson is offline   Reply With Quote
Old   August 21, 2013, 15:23
A CFD free user's Avatar
A-A Azarafza
A CFD free user is on a distinguished road
Hello guy
Yes it's quite possible in Fluent. Just define a line and then plot your interest data by xy plot tools. It's also possible in Tecplot which I don't know how exactly it is.
Regard yours
A CFD free user is offline   Reply With Quote
Old   August 22, 2013, 00:12
Dinesh Babu
Is it possible to plot different vel profile with geo outline in fluent..? Can u brief it?
Old   August 22, 2013, 12:15
A-A Azarafza
Hi
I didn't take your point by saying geometry outline! Do you mean the basic frame of the geometry? I gotta say that you can plot all profile in the same way I told you before. Just define a line and then plot the variables along it. So easy and straightforward.
Regard yours
Old   October 23, 2013, 04:09
Default Plotting Software
sid
sid
sid is on a distinguished road
Can anyone let me know a good plotting software rather than excel for plotting my transient analysis data i.e., obtained from fluent?
I tried in excel but im expecting a higher quality graph to plot large amounts of data.
Thank you
sid is offline   Reply With Quote
Old   December 30, 2014, 15:40
Default Not the most elegant, but gets the job done
Tencho
supvato is on a distinguished road
To answer the question in the title...
I believe the easiest way is to create a new variable in "Data> Alter> Specify equations..." using the velocity in the axial direction, say V3, and offsetting it with the axial position (say V1) as follows,
V5=c*V3 + V1,
where c is a constant to adjust the 'depth' of the profile.
After this, you can plot V5 vs. V2 (the radial position). This will give you a series of profiles positioned along the axial direction. If you find that the profiles are too close together, you can skip points in the "Indices" tab of the "Mapping Style..." menu or change the value of c. You need to make sure that the you choose V5 as the dependent variable in "Mapping Styles...>Definitions".
While there may be more elegant ways of doing this, I believe this is a relatively simple way of getting profiles along the axial direction.
supvato is offline   Reply With Quote
fluent 13, tecplot, velocity profile, xy plot
UDF inlet velocity profile mismatch with Fluent ChristineL Fluent UDF and Scheme Programming 15 November 25, 2016 06:45
Shear stress from velocity profile baranii2000 COMSOL 4 November 11, 2015 04:08
Velocity profile boundary condition Tuca FLOW-3D 1 April 23, 2013 12:02
How to apply an outlet velocity profile to another inlet? siw FLUENT 4 April 10, 2013 11:19
Plot velocity profile at different position AirS Main CFD Forum 2 December 3, 2010 06:03
