Home > Forums > Visualization & Post-Processing Software > Tecplot
on Tecplot
Old   August 21, 2006, 10:36
Default on Tecplot
Vic
I have some results for flow around an airfoil in a wall-bounded domain (something like an airfoil installed in a test section of a wind tunnel). In TECPLOT, it is easy to create a slice in any direction and see the 2D streamlines. But, I would like to remove the solid walls so that the only thing that I see is the airfoil and the 3D streamlines around it.
Or in another but similar case, there is a 3D rectangular domain (like a box) and a duct is attached to the lower surface and let some amount of air goes out. Again, I want to remove all solid boundaries except for the duct and the flat plat (side) that this duct is attached to, so that I can see how the streamlines approach and enter the duct.
I appreciate any advice/idea on how I can manage this.
Vic
Old   August 28, 2006, 07:49
Default Re: on Tecplot
Gerrit
I'm afraid you can't. If you want to take away the walls they should have been saved as separate zones from the beginning, you then just turn off that zone. Or maybe you just have to turn off the boundary on the left hand side.
If the're not saved as separate zones... ...you can't
I hope I understand your question.
Importing contour maps into Tecplot jcostex Tecplot 1 May 20, 2009 12:48
Problem Exporting to Tecplot Craig FLUENT 2 July 15, 2008 23:21
How to read tecplot file witout tecplot ? Pol Tecplot 11 March 2, 2007 06:26
Using Tecplot for contours display david FLUENT 2 August 23, 2005 22:37
Tecplot can't read data file from Fluent. stephen FLUENT 8 November 21, 2001 20:27
