Home > Forums > Visualization & Post-Processing Software > Tecplot
tecplot
Old   May 29, 2007, 15:39
Default tecplot
Nik
Hi I want to generate a movie using tecplot. The problem is that tecplot frame is big relative to data(countour data in x-y coordinates). so, when you generate an avi file,you will have big white field around your data.when you resize the frame, the data will be resized as well. Is there anyway to resize the frame without resizing the data?
Thanks
Old   June 1, 2007, 00:51
Default Re: tecplot
Shyam
Once you resize your frames, you can use the zoom to fit option in tecplot. Note that you need to use all the frames while doing this. Hope I answered your query.
Old   June 9, 2007, 01:10
Default Re: tecplot
sam
how to make a movie in techplot? are you using techplot 360?
Old   June 11, 2007, 15:30
Default Re: tecplot
Zach
I've been having some issues generating a .avi movie in general. Using the Animate to AVI, I can't seem to get a movie. A .avi file is created but the file is an empty black screen. Any thoughts?
Old   June 17, 2007, 15:19
Default Re: tecplot
Arash S
Hi
In my finite element problem, I have brake elements with 27 nodes, when I import the mesh data (scalar file) to tecplot It knows my elements as brakes with 8 nodes and divides each 27 node brake element to 8 sub-elements ( 8 brakes with 8 nodes). How can I solve it, may been it the limitation of tecplot? Thanks
Importing contour maps into Tecplot jcostex Tecplot 1 May 20, 2009 12:48
Problem Exporting to Tecplot Craig FLUENT 2 July 15, 2008 23:21
How to read tecplot file witout tecplot ? Pol Tecplot 11 March 2, 2007 06:26
Using Tecplot for contours display david FLUENT 2 August 23, 2005 22:37
Tecplot can't read data file from Fluent. stephen FLUENT 8 November 21, 2001 20:27
