Velocity profiles at different axial locations from a 3D geometry |
September 15, 2014, 07:23 |
Hi all,
I'm new to tecplot, I'm trying to do something fairly simple and can't seem to find the solution. I have a 3D (rectangular) geometry where x is the axial direction. I can generate a velocity profile of Ui with respect to y or z easily. I first extract the slice (in this case at y=0) that I am interested in. Then on the top left corner, I select 2D cartesian instead of 3D cartesian and adjust the parameters in Plot--> axis, assign axis to generate my velocity profile. The problem is that I don't know which x location is this 2D plot taken from. And I also don't know how to change x-locations. Any help? |
plot, velocity profile |
axial turbine stage geometry | brunorm | Fidelity CFD | 0 | July 4, 2013 12:52 |
Lid Driven Cavity velocity profiles | new_at_this | Main CFD Forum | 0 | December 22, 2011 16:04 |
axial velocity in bend pipe with adverse pressure gradient | liguifan | OpenFOAM | 0 | July 24, 2011 05:56 |
Velocity profiles problem behind the elbow (3D problem) | kabat73 | FLUENT | 8 | May 9, 2010 04:26 |
Velocity profiles | merac | FLUENT | 2 | May 23, 2001 04:54 |
