Home > Forums > Visualization & Post-Processing Software > Tecplot
Contour type in Tecplot360
Like Tree2Likes
  • 1 Post By scott_rumage
  • 1 Post By openfoammaofnepo
Old   April 10, 2015, 01:06
Default Contour type in Tecplot360
openfoammaofnepo is on a distinguished road
Dear All,
I select "Flood and Lines" under "Contour type". For the lines I would like to use it to visualize the iso-lines, e.g. T=1800 K. In the Tecplot 360, is it possible to two iso-lines corresponding to two quantities, for example, T=1800K and Ux=0. In this case, I should select two lines, however, in Tecplot 360, there is only one line.
Anybody know if it is possible to plot out two iso-lines corresonding to two quantities?
Thank you in advance.
OFFO
openfoammaofnepo is offline   Reply With Quote
Old   April 13, 2015, 11:46
Scott Rumage
scott_rumage is on a distinguished road
One way to do this is to layer transparent frames one on top of another (with the bottom frame not transparent) to create the needed plot. The linking and layering of the frames is done via the menu Frame>>Frame Linking.
An example of this layering is on your computer in the Tecplot folder C:\Program Files\Tecplot\Tecplot 360 EX 2015 R1\examples\2D and is called AeronauticalPlot.lpk . The idea is that you would create a line contour of T in one frame (and then make the plot background transparent), and then make a second plot in a new frame of contours lines of Ux.Then link the two plots together in size and location, and put the frame with the transparent background on top of the other.
A screen shot of the plot is below AeronauticalPlot is attached.
Scott
JerimiahLee likes this.
scott_rumage is offline   Reply With Quote
Old   April 13, 2015, 22:49
Dear Scott,
This is a really good idea. I think this can work and I will have a try with it. Thank you very much for your help.
All the best,
OFFO
Scott
Old   April 20, 2015, 12:39
Scott Rumage
An associate of mine mentioned another way to achieve the plotting of two variables from one zone. The process is to duplicate the zone (via Data>>Create Zone>>Duplicate), and then make both zones active and plot T in one zone, and Ux in the other duplicated zone.
This method should not use too much more memory, and is easier than layering frames.
Scott
Old   April 20, 2015, 12:43
Dear Scott,
You are so kind. The suggestion is very helpful! I will try this method.
BTW, did you have the plane to include this function in the new version of Tecplot360? Because I think in many occasions we need to plot two iso-lines that correspodn to two quantities.
Thank you very much.
OFFO
Scott
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
Simulation of Radial Fan with simpleFoam MRF nash OpenFOAM Running, Solving & CFD 2 November 5, 2015 10:12
interFoam/kOmegaSST tank filling with printStackError/Mules simpomann OpenFOAM Running, Solving & CFD 3 February 17, 2014 17:06
T Junction Stability ignacio OpenFOAM Running, Solving & CFD 5 May 2, 2013 10:44
pipe flow with heat transfer Fabian OpenFOAM 2 December 12, 2009 04:53
