Slice constraint in Tecplot 360 is not available |
May 28, 2015, 00:45 |
gautham narayan
Rep Power: 11 |
I am currently using tecplot 360 fully functional trial version. According to the pdf manual the slices can be constrained by selecting the contraint option in slice>detail>constrain tab.
I am not able to find the constrain tab here. i can find all the other mentioned tabs, but the not this one. It would be great if someone could direct me towards the solution. thanks, |
May 29, 2015, 10:59 |
Scott Rumage
The constrained slice feature is not available in Tecplot 360 EX.However, it is available in Tecplot 360 2013.So one option is to download & install 360 2013 from this page: http://www.tecplot.com/my/product-releases/ .
As an fyi the trial key will run this older version, and you can have both 360 2013 and 360 EX 2015 on your computer without conflict (so you can compare the two versions). If you do a comparison, you will notice that the two versions have different UIs. Tecplot has updated the UI for 360 EX (and this is most noticeable for Linux and Mac versions). Constrained slicing will be a capability for 360 EX in the future, but I dont have a date when that will happen. Cheers, Scott |
January 25, 2016, 12:12 |
Same thing in Techplot 360 EX 2014 & 2015 R2
#3 | |
Hasan K.J.
Dear Scott,
I would like to do the same thing whats happening in the video in Techplot 2014 and 2015 but the options seem totally different, can you please tell me how to extract constrained slices in 2014 & 2015 Regards, Hasan K.J
"Real knowledge is to know the extent of one's ignorance." - Confucius |
January 27, 2016, 13:28 |
Constrained slice macro for 360 EX
Scott Rumage
Hello Hasan,
The constrained slice feature is not available Tecplot 360 EX 2014, 2015 ,and 2016. However you may find this macro will meet your requirements (with the proper edits on for your application) #!MC 1400 $!GLOBALCONTOUR 1 VAR = 7 # the number of your contour variable, e.g. V7 in this example # set contour, turn slice on $!CONTOURLEVELS RESETTONICE CONTOURGROUP = 1 APPROXNUMVALUES = 15 $!SLICELAYERS SHOW = YES $!SLICEATTRIBUTES 1 SLICECONSTRAINT{INCLUDE = YES} # box dimension values $!SLICEATTRIBUTES 1 SLICECONSTRAINT{BOXDIMENSION{X = 1}} $!SLICEATTRIBUTES 1 SLICECONSTRAINT{BOXDIMENSION{Y = 0.5}} $!SLICEATTRIBUTES 1 SLICECONSTRAINT{BOXDIMENSION{Z = 0.245}} # box center values $!SLICEATTRIBUTES 1 SLICECONSTRAINT{ORIGIN{X = 0.6}} $!SLICEATTRIBUTES 1 SLICECONSTRAINT{ORIGIN{Y = 0.5}} $!SLICEATTRIBUTES 1 SLICECONSTRAINT{ORIGIN{Z = 0.2}} $!REDRAWALL Scott |
Fast Fourier Transform (FFT) in Tecplot 360 | g.woyczynski | Tecplot | 5 | October 26, 2017 11:09 |
Tecplot 360 2011 R2 preview with OpenFOAM data loader available for evaluation | scott_rumage | OpenFOAM Post-Processing | 50 | January 23, 2017 02:49 |
How to plot contour lines in Tecplot 360 using Excel file | Iqbal | Tecplot | 1 | May 30, 2012 19:22 |
CFX-Post and Tecplot 360 | Rogerio Fernandes Brito | CFX | 2 | September 28, 2008 14:45 |
Bounded slice in Tecplot possible? | Sam | Tecplot | 1 | August 20, 2008 12:18 |
