February 24, 2017, 16:47 |
Tecplot .plt file to cgns format
Akshay Bagi
Rep Power: 13 |
I have a .plt file that is an output of starccm+. It has mesh and solution data in it. I want to convert this .plt file into a cgns file that has mesh and solution data again. Can anyone please tell me how to do this? Thanks Akshay |
February 24, 2017, 23:22 |
Rep Power: 12 |
Output it directly from Star. The direct CGNS output is better anyways. If you are running into the 64bit issue loading into tecplot try 2017R1 as it supports 64bit CGNS
February 25, 2017, 01:38 |
Akshay Bagi
Rep Power: 13 |
Hi novedevon,
The problem is star can only output only mesh data and no solution data. I need the CGNS file to contain both mesh and solution data. Star doesn't support that. Cheers Akshay |
.plt, cgns, conversion, starccm+, tecplot |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
pisoFoam compiling error with OF 1.7.1 on MAC OSX | Greg Givogue | OpenFOAM Programming & Development | 3 | March 4, 2011 17:18 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 11:46 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
