Home > Forums > Visualization & Post-Processing Software > Tecplot
plottting tangnetial and axial velocity vectors on a plane
Old   March 21, 2017, 14:18
Default plottting tangnetial and axial velocity vectors on a plane
Shamoon Jamshed
Shamoon Jamshed is on a distinguished road
Send a message via Skype™ to Shamoon Jamshed
Hello all,
I am simulating a rotational flow in a pipe whose flow velocity was specified as axial, radial and tangential with axial being the direction of flow in z direction in Fluent.
In Tecplot
Now when I take this geometry I want to see velocity vectors on plane. Here I do not see radial axial or tangential rather u, v , w as velocity components.
Q1: Do I need to change u,v, w from x,y and z components to w,v,u b/c my z velocity (w-component) is in axial direction. Does tecplot sense z direction as axial by default ?
Q2. Do I need to define in specify equations and write explicitly the equations for axial , radial and tangential velocities?
Shamoon Jamshed is offline   Reply With Quote
Old   December 1, 2017, 13:41
Shamoon Jamshed
Any response please?
Old   December 4, 2017, 13:55
novedevon is on a distinguished road
At this point Tecplot does not support direct cylindrical plotting for either spatial or vector coordinates. As such everything must be defined by X,Y,Z and U,V,W. As long as you have defined X,Y,Z as your spacial coordinates (in Plot>Assign XYZ) you should correspondingly define U,V,W as your vector variables (see Plot>Vector>Variables).
Assuming you are interested in vectors on a slice or an existing surface zone, you can use U,V,Wthe either use the default representation or select "Tangent Vectors" (Slice Details>Vectors page or Zone Style>Vectors page) which will show only the tangent component of the vector.
If you only have axial, radial and tangential velocities defined in your input file you will have to use Data>Alter>Specify Equations to calculate U,V and W using the standard conversion equations. And no, Tecplot cannot detect any axial direction by default so that we can be as process neutral as possible.
If you have any followup questions feel free to contact Tecplot support at support@tecplot.com
-Devon Simpson
Tecplot Technical Product Manager
novedevon is offline   Reply With Quote
