Home > Forums > Visualization & Post-Processing Software > Tecplot
Write Data as Formatted Text
Old   May 21, 2021, 06:01
Default Write Data as Formatted Text
none
starz is on a distinguished road
Dear friends,
I have a question. I tried to write data to csv file from Tecplot. I want to export a few variables. I use Tools > Write Data as Formatted Text. However, in the "choose variable", I can only see the coordinate axis. And it is not possible to select any variables. Actually, I have loaded these variables and they are visible in the plotted frame.
Thanks!
starz is offline   Reply With Quote
Old   May 24, 2021, 11:46
Brandon M
Brandon_CFD is on a distinguished road
The Write Data as Formatted Text File dialog only writes-out nodal variable values. In order to write out your variables, you can us Data>Alter>Specify Equations... and then create a nodal version of your duzz variable or other variables. Make sure to specify nodal in "Var Location" (see 3:35 in this video here: https://www.tecplot.com/2020/09/02/t...ics-equations/ )
Here is an example equation:
{duzz_cc} = {duzz}
Brandon_CFD is offline   Reply With Quote
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 13:06
How to write OpenFoam data from memory, do not write on hard disk Tanwk OpenFOAM Programming & Development 0 September 14, 2020 03:50
UDF value to large for defined data type Anna73 Fluent UDF and Scheme Programming 9 September 30, 2018 22:18
UDF - Write data into file at the end of every time-step rookiecfd Fluent UDF and Scheme Programming 7 April 17, 2017 11:21
[Helyx OS] Helyx-OS (GUI for SnappyHexMesh elvis OpenFOAM Community Contributions 210 January 30, 2017 18:57
