February 17, 2020, 19:06 |
importing cas and data files from Fluent
Azadeh
Rep Power: 11 |
Hi
I have a problem with importing cas and data files from Fluent. The geometry is a bend that looks like the attached bend_ file. But, when I load cas and data files to tecplot, it looks like the attached bend_tecplot file. I was wondering if any of you are able to help me to figure out the problem. Thanks in advance Navid |
February 18, 2020, 18:03 |
Svetlana Tkachenko
Rep Power: 14 |
Can you please attach an example?
February 19, 2020, 21:55 |
Azadeh
Rep Power: 11 |
Thanks for your reply
Unfortunately, cas and data files are too big (more than 1Gb). One side of the bend pipe appeared to be flat once I open it with Tecplot, as attached in the question. (that is what I got from Tecplot). However, the cas and data files are working well with CFD-post. Cheers Navid |
February 20, 2020, 19:06 |
Svetlana Tkachenko
Rep Power: 14 |
Hi azi/Navid
There is 2GB of space in dropbox free account. Perhaps attach the first file and post it here. After I download it, remove it from your dropbox and upload the other file. Regards Svetlana |
February 21, 2020, 00:41 |
Azadeh
Rep Power: 11 |
Hi Svetlana
Thanks for your reply. Here is the link for both cas and data files https://universityofadelaide.box.com...2yls6t9njkegl5 Thanks a lot Navid |
March 3, 2020, 13:56 |
Brandon M
Rep Power: 7 |
Hello Azadeh,
The axis scaling needs to be adjusted. I attempted to adjust the Y axis scaling to 1 initially and found that I needed to first extend the Data Aspect ratio limit to 30. Let us know if you have additional questions at support@tecplot.com. |
Easy way for exporting data from fluent | seyedashraf | FLUENT | 2 | February 19, 2016 04:20 |
error in load cas & data files | sara22 | Tecplot | 0 | April 3, 2014 10:21 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
Two conditions in Fluent journal files | bobmalaria | FLUENT | 5 | November 10, 2011 05:31 |
[making animations] fclose fails to close files? | Mika | FLUENT | 0 | March 30, 2001 08:19 |
