Home > Forums > Visualization & Post-Processing Software > Tecplot
Problem with boundary conditions
Like Tree1Likes
  • 1 Post By giack
Old   August 1, 2013, 06:20
Default Problem with boundary conditions
giack is on a distinguished road
Hi to all,
I have a simple question about how Bcs are treated by tecplot. When I load the simulation Tecplot doesn't load the Bcs and the value in the last domain cells is wrong. Someone knows the reason of this strange behaviour?
Thanks to all
SFWalter likes this.
giack is offline   Reply With Quote
Old   April 6, 2020, 12:02
Sibylle Walter
SFWalter is on a distinguished road
What is the file type you're reading into Tecplot? And what are you outputting from your CFD solver?
Generally, Tecplot will have zones where each zone should correspond to a boundary. Depending on how your CFD model was set up, it will be called something different.
SFWalter is offline   Reply With Quote
Old   April 27, 2020, 23:35
Shawnnnn is on a distinguished road
Hi Giack,
Do you mean the last cells close to boundaries (like walls) do not behave the way like you defined your BCs? If so, you can try to select Zone Style -> Contour -> Contour Type -> Primary value. There might be linear interpolation if use Flood in contour type.
Hope that helps.
Shawnnnn is offline   Reply With Quote
boundary condition, openfoam, tecplot
ribbed channel / simpleFoam / boundary conditions beeo OpenFOAM Pre-Processing 20 July 17, 2013 08:39
Problem with Periodic Boundary Conditions Help!!! otsigun FLUENT 0 July 11, 2013 03:20
Boundary Conditions problem o_mars_2010 Main CFD Forum 2 July 8, 2013 02:10
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
Problem with Boundary conditions Mahiboobswamulu Main CFD Forum 10 August 26, 2003 13:24
