Home > Forums > Visualization & Post-Processing Software > Tecplot
Exporting Tecplot Files
Old   May 19, 1999, 06:02
Default Exporting Tecplot Files
Sam Zakrzewski
Dear CFD Users
I'm using Fluent 5 to model an unsteady case I'm trying to get it to export a Tecplot file at the end of each timestep.
In Monitors- Command, I set the command no. to 1, Every... to 1, When... to time step and write "file export tecplot data-%t.tec vm ch4 temp" in the command window then i iterate
It works ok for the first time step and produces data-0000.tec it then proceeds to do time step 2 it then attempts to save and tries produce data-0000.tec again, even though it should produce data-0001.tec. It even asks if i want to over write data-0000.tec even though the online manual claims it should not. Am I doing something wrong? I've posted this to a few CFD usernets, with limited sucess maybe i'll have more luck here!!
Cheers Sam
Old   May 19, 1999, 11:30
Default Re: Exporting Tecplot Files
John C. Chien
(1).I think Fluent and Tecplot are sponsors of this forum. Don't you think that it is easier to get answers directly from them? (2). Well, unless it is a non-official version. (3). Obviously, A USER + A CODE x= ANSWER in this business. (4). Try to make friends with code vendors first, in this way, A VENDOR + A FRIEND + A USER + A CODE = ANSWER. (5) ARE YOU LEARNING ?
Old   May 19, 1999, 13:05
Sung-Eun Kim
Dear client,
We'll get back to you shortly as soon as we find what possibly went wrong. By the way, you said you posted this question on other CFD usernet. I wonder if you've contacted your local support enginee about this possible bugr. We have our distributor in Austrailia CFD-RES (Tel: 61 2 9209 4580)
Sorry for inconvenience
Old   May 20, 1999, 04:32
Harsh Vardhan
Dear Mr Sam,
This was due to a small bug in the code which has been fixed. Please contact your Fluent support engineer to get the latest executable.
Incedently, with the new exec, the command will change to:
"file export tecplot data-%t.tec , vm ch4 temp q"
Harsh
UDF issue MASOUD Fluent UDF and Scheme Programming 14 December 6, 2012 13:39
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
Trouble with exporting tecplot files from FLUENT Argen FLUENT 2 January 5, 2010 02:42
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
fluent case n data files not exporting to tecplot krishna FLUENT 2 February 17, 2007 23:24
