Tecplot: Projection of a parameter on a plane |
March 17, 2011, 12:05 |
Lysandre
I use tecplot 360 (or rather the OEM version tecplot SV from Synopsys) to visualize the results of some device simulations of photodiodes. The structure is in 3D and I would like to extract along Z (the depth of the photodiode) the maximum electrostatic potential. Then I want to project in an X-Y plane this maximum electrostatic potential.
How can I do that? I couldn't find a way to extract the maximum of parameter along a direction either in the GUI or with the scipting language.. Thank you all for your help |
March 18, 2011, 18:18 |
Extracting a plane in Tecplot tutorial
Scott Rumage
What you are seeking to do may be explained in this tutorial found on Tecplot's web site: http://download.tecplot.com/360/tuto...low/index.html and go to "Extracting a Slice Plane and Plotting a Variable".
Regards, Scott |
March 21, 2011, 10:55 |
Lysandre
I watched the tutorial and this is not the same thing as what I try to do. For an example of the final result I would like to reach, you can look at the second page of this paper: http://www.imagesensors.org/Past%20W...%20et%20al.pdf. It is here a 2D projection of the maximum electrostatic potential in the structure. This is not the same a doing a simple slice at a given Z coordinate because the maximum electrostatic potential for a given (X,Y) may be at various depth Z.
I know this is not CFD but since you all use similar softwares, I guess some people have already done this kind of things, which can be applied to other parameters. |
May 26, 2012, 03:01 |
Oliver Pasqual
Dear Lysandre
Have you solved your problem? It's interesting and I want to do a similar operation using tecplot. many effort have been paid on this problem, but the problem can't be fixed. Any hints or suggestion will be highly appreciated. Kindly Regards oliver |
projection method, tecplot |
arbitrary function plot on Tecplot xy plane | dokeun | FLUENT | 1 | December 20, 2010 21:38 |
Meshing a Mixing Plane using ICEM | Will Anderson | FLUENT | 0 | November 6, 2010 17:08 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 12:43 |
compile errors of boundary condition "expDirectionMixed" | liying02ts | OpenFOAM Bugs | 2 | February 1, 2010 20:11 |
