Home > Forums > Visualization & Post-Processing Software > Tecplot
Animation by Tecplot
Old   July 31, 2005, 11:48
Default Animation by Tecplot
Daniel
Hi, I want to make an animation using a sequence of instantaneous streamlines in Tecplot. It should be possible to select different initial points for the streamlines for each frame (called zone). Basically I want to change some parameters for view details for different frames inside the animation. do you know how?
The other option is to export figures from tecplot and then doing the animation with a movie maker, but it seems the quality gets worse, much worse. Any suggestion is wellcome. Daniel
Old   August 2, 2005, 05:13
Default Re: Animation by Tecplot
Vinod Dhiman
Hi
You can directly go to tools > animate, and then depending upon the availability, eg. you may have different zones, you can animate zones, one will be visible at one time, and it will create a movie.
Animation step by time in Tecplot SeungWon, Jeon Tecplot 0 July 3, 2008 05:06
Animation with CGNS file in tecplot Farid CFX 1 January 25, 2008 10:20
Multiblock animation in Tecplot. Simon Tecplot 4 February 10, 2006 10:27
Animation query..newbie qn derick FLUENT 2 December 9, 2005 09:45
Animation in Tecplot ryoga Tecplot 0 February 18, 2002 11:19
