[DesignModeler] Creating Two Separate Bodies in Design Modeller
Like Tree9Likes
Old   April 23, 2012, 09:39
Question Creating Two Separate Bodies in Design Modeller
Ashkan Javadzadegan
ashtonJ is on a distinguished road
Dear All,
In design modeller, I want to create two separate bodies(two separate parts) using different sketches. When I create a new sketch and make it 3D, the new 3D body and previous 3D body are known as 1 Part, however, I want them to be 2 separate parts.
Does anybody know how to do that.
Kind regards,
ashtonJ
ashtonJ is offline   Reply With Quote
Old   April 23, 2012, 19:15
Gweher's Avatar
Gwenael H.
Gweher will become famous soon enough
Did you use the Search option? there are plenty of topics relating your question as your post regarding the "Revolve in Design Modeller" you could search before asking... Tutorials are a good way to get started with DM and the WB in general.
But I give you a hint, use "add frozen" when you create your second body.
Gweher is offline   Reply With Quote
Old   June 5, 2012, 02:00
Default Hi gweher
Danial
Danial Q is on a distinguished road
I have same question (as ashton) and I tried following options to make them separate two bodies, unfortunately din't work ;
1> add frozen ( i wanted interface between two bodies, so when i was setting physics in "Pre", it considered it only one body.
2>. using offset TO CREATE 2ND BODY in same plane, because both solid bodies are boxes and placed one above the other (with one common face) ,it again results in same problem, 1 part,1 body.
could you please point out my mistake??
Thanks
Danial Q is offline   Reply With Quote
Old   June 5, 2012, 02:19
Gweher's Avatar
Gwenael H.
Danial,
The add frozen option should work. I don't have enough info from your post to help you further. Could you please add an image of your problem and what you are trying to model. Add the .agdb file
Old   June 5, 2012, 02:36
Default Hi
Danial
I am trying to make two bodies with one common face, infcat fluid and solid domains.i have atatched the pic.
Thanks
Old   June 5, 2012, 02:43
Default Hi Gweher
Danial
thanks bro, it seems i was desaling with unfinished business, i dint create second domain to make interface work.my baddddddd!
Thanks again
Gweher's Avatar
Gwenael H.
You are nearly there, just select the two parts, right click >form new part and then it should be fine.
dibetao, etinavid and Assidefok like this.
Old   June 5, 2012, 03:12
Default Hi gweher
Danial
Thanks, though it worked without forming new part but still i learnt a new thing by forming new part , it could be done. cheers
Thanks again
Old   May 30, 2013, 21:13
Mahboobe Mahdavi
Mahboobe365 is on a distinguished road
Can I know how did you build two parts with common face with out using the form new paart,I have the same problem.
Thanks
Mahboobe365 is offline   Reply With Quote
Old   December 4, 2013, 02:50
marzieh
msara is on a distinguished road
In design modeller, I want to create and meshing two CUBIC that one of them is in the other one with separate bodies(two separate parts) using different sketches.
please help me.
I could create two cubic in geometry space, create larger one then create smaller one in different skeche with select add frozen instead of add material,but when I want to generate mesh ,some error would be created.
msara is offline   Reply With Quote
Old   December 4, 2013, 06:18
vidyanand
Vidyanand Kesti is on a distinguished road
send me more details and picture
Vidyanand Kesti is offline   Reply With Quote
Old   January 8, 2014, 18:09
JohnnyJ
gaurav_prabhudesai is on a distinguished road
@msara
Instead of frozen, use "slice". That should do the job. Two separate bodies will be created.
Cheers !
gaurav_prabhudesai is offline   Reply With Quote
Old   January 10, 2014, 11:21
Mahboobe Mahdavi
Thank you, Would you please explain more?
Old   January 13, 2014, 16:17
JohnnyJ
1) Extrude the first body using the first sketch
2) When you extrude the second body from the second sketch, instead of "frozen", try "slice"
The slice option will slice the body 1 as body from sketch 2 is extruded. Try this out and let me know if this works for meshing.
The issue is, with frozen, the two bodies are treated independently. The problem arises when one body is inside the another. When you choose frozen, the first body and second body both exist. So an overlap of volumes is created which causes the problem. Slice option extrudes body from sketch 2 while subtracting the intersection portion. So no overlaps
thermal energy, Fedor and RudolfZ like this.
Old   June 3, 2014, 12:03
Vivekananda Bal
vivekananda is on a distinguished road
ya. if you do with frozen, you will have two independent body. But if you use slice option you will have two separate bodies. The interface will have src, trg and several wall regions. If you add to bodies using form new part, you will have interace common to both bodies. But you will have interface regions with
wall-part-fluid, wall-part-solid, wall-part-fluid-part-solid, and shadow regions.
Does anyone know why this happens? How to create common interface?
thermal energy likes this.
vivekananda is offline   Reply With Quote
Old   February 19, 2015, 16:59
azna
azna is on a distinguished road
May I know the process / option to rotate the ''sketch "in Design Modeler?
azna is offline   Reply With Quote
Old   May 27, 2015, 00:24
chigs
chirag.palan1987@yahoo.in is on a distinguished road
i want to create solid cylinder in flow domain, while modeling should i use 'cut material','add material' or 'add frozen'?
please help
chirag.palan1987@yahoo.in is offline   Reply With Quote
Old   May 27, 2015, 01:45
Kapi is on a distinguished road
add frozen!
Try few tutorials, cuz all these things are covered in tutorials.
Plus you can very well try all 3 options and see what different things you are getting.
It will help in future!
Cheers
KAPI
Kapi is offline   Reply With Quote
Old   May 27, 2015, 01:54
chigs
thnx i will look for tutorials
Old   July 28, 2015, 10:05
Sazeda Begam
sazeda is on a distinguished road
How can I create 2 or 3 part, 1 body.
In my case 1/2 body is inside the another. When I choose frozen, the first body and second body both exist. So an overlap of volumes is created which causes the problem. I also tried with the 'slice' option; it results same as 'frozen' option.
Please help....
sazeda is offline   Reply With Quote
Design modeller ease to use taw CFX 4 May 2, 2011 15:51
[Other] Import autocad into Design modeller lcea ANSYS Meshing & Geometry 1 December 1, 2010 13:15
surface bodies from design modeler to CFX chisa CFX 0 June 9, 2010 11:36
creating a solid body in Design Modeller Dan CFX 0 May 24, 2004 11:59
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 10:18
