[GAMBIT] Problem in generation oval surface
Old   May 1, 2012, 15:02
Default Problem in generation oval surface
cfd
wind.cfd is on a distinguished road
I want to create the oval shape pipe. because it is connected to two other cylinder, I want to create the 2D geometry and then revolve them to generate 3D shape. My problem is that I dont know how to do that. I would really appreciated if someone let me know how is is possible?
Thanks alot
wind.cfd is offline   Reply With Quote
Old   May 2, 2012, 02:54
-mAx-'s Avatar
Maxime Perelli
can you post a sketch of what you want exactly
Old   May 2, 2012, 12:03
cfd
Tnx mAx for your attention,
I don't know how to attach my file to show you my model?!
Could you help me
Old   May 2, 2012, 12:42
cfd
Actually when I create the ellipse edge and want to sweep the edge, I gave the following error: the edge being swept has moved from its original location. Try changing the default GEOMETRY.VOLUME.SWEEP_PATH_ALIGNMENT to 1 or try aligning the path(edge/vector) to start from edge being swept.
ERROR: sweeping or revolving edge edge.3 failed
Do you know what should I do?
Old   May 3, 2012, 01:09
-mAx-'s Avatar
Maxime Perelli
http://www.cfd-online.com/Forums/faq...b3_attachments
Old   May 4, 2012, 19:09
cfd
p { margin-bottom: 0.08in; } Hi mAx,
I have attached the pics of my model, also I have written the process of the generation.
The process of generating this geometry
  1. create edge circle AB (which is the interface of oval and large cylinder)
  2. create face circle AB
  3. create oval face EF (which is the interface of oval and large cylinder)
  4. sweep oval face EF to generate volume
  5. delete oval volume to remain oval surface
  6. subtract oval face from circle
  7. sweep circle face AB to create volume
  8. create edge circle CD (which is the interface of oval and small cylinder)
  9. create face circle CD
  10. subtract oval surface which is connected to the above face
  11. sweep edge circle CD to create face
Actually, I do this process because I need to define the boundary layer same in attached pic.
Now I want to create three separate volumes (large cylinder, small cylinder, oval cylinder)
but when I do that I get the error regarding to open shell.
What do you think about the process I applied?
TNX
Old   May 14, 2012, 01:45
-mAx-'s Avatar
Maxime Perelli
I received your files.
You cannot mesh your ellipse volume, because auf highly skewed element on top and bottom caps.
I you delete your mesh, and enable shaded modus on, you will see something is wrong
Now you need to know that gambit is dimensionless, so try to create the ellipse (create cylinder) with r1=333, r2=3000 and height 2000. (you will be able to scale your model later in fluent)
Then you may try to create your size function. (on the picture, I splited the edge twice, for having an edge just at the curvature and I applied a fixed size function an this edge)
Old   May 15, 2012, 13:24
cfd
Attachment 13104
Attachment 13105
Attachment 13106
Thanks a lot for your consideration
Thats right my mesh has a high skewness at top and bottom, so I have to change the mesh.
Could you tell me how you split the edge and create the mesh on the top edge, I could not do that. If you tell me the steps I would really appreciated.
Old   May 16, 2012, 00:30
-mAx-'s Avatar
Maxime Perelli
edge>split edge with location
the edge will be splitted where you are cliking on.
Do the procedure twice for isolating and edge at the curvature.
Then create your size function with fixed option and select your edge as source
[ICEM] Patch dependent surface mesh problem! hadikhayyamian ANSYS Meshing & Geometry 14 January 27, 2018 08:47
Problem Concerning free surface wave simulation michaels STAR-CCM+ 3 February 25, 2011 07:28
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
Heat Generation as time dependent problem Denis Kadito FLUENT 0 April 17, 2001 16:28
