[GAMBIT] Line/curve meshing
Old   June 9, 2012, 15:45
Default Line/curve meshing
Robert
Kwiaci is on a distinguished road
I have following problem:
In the atachement there is simple geometry consisting of two lines and one curve. I need to mesh the bottom line and upper curve in such way that I will get vertical lines connecting corresponding points.
How can I do it in Gambit?
Kwiaci is offline   Reply With Quote
Old   June 11, 2012, 01:08
-mAx-'s Avatar
Maxime Perelli
You will have skewed cells where the curve is normal to bottom edge.
But if you really want this, then check User Guide at section "3.3.4 Set Face Vertex Type"
But you will have problem since you have 11 nodes at bottom edge, and 17 nodes on upper curve
Old   June 11, 2012, 14:06
Robert
Eventually, I have managed to get mesh like in the attachment - it's not exactly what I wanted but quite close. And you are right - there are problems on the left side of the curve.
Perfect mesh qould be similar to this in Fluent VOF tutorial:
http://www.scribd.com/doc/44071057/F...-the-VOF-Model
Old   June 12, 2012, 01:34
-mAx-'s Avatar
Maxime Perelli
the difference with the tutorial is that in your case, the curve is starting tangential to the left edge. (in the tutorial the curve isn't ending tangential to the right edge)
In your case you can choose another mesh schema: Quad Tri-primitive
curves, meshing advice
Best Meshing scheme for Cylinder Nutrex Main CFD Forum 4 July 29, 2008 11:03
Meshing locks workbench window. andy2o CFX 0 February 1, 2008 05:01
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 11:09
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 11:08
