[DesignModeler] Design Modeler: Split faces
Old   December 6, 2012, 11:29
Default Design Modeler: Split faces
Luis.Castro is on a distinguished road
Hi everybody,
I am trying to make a simple 2D model and I need 3 independent bodies next to each other. i make 3 different sketches but when I create a "Surface from Sketch" they combine to produce a single body. I need the bodies to be independent!.
I tried with "Split Faces" but somehow it doesn't work.
Thanks for your help
Luis.Castro is offline   Reply With Quote
Old   December 6, 2012, 11:46
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
when using the surface from sketch, did you try selecting not the boundary of the hole model but the each surface alone...
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   December 7, 2012, 05:49
Yes I do the "surface from sketch" in the concept tab from each individual sketch
Old   December 10, 2012, 04:19
No solutions?
Old   December 10, 2012, 04:30
Josef Runsten
jrunsten will become famous soon enough
Send a message via MSN to jrunsten
Do you actually have three different sketches in the model tree or have you just sketched three shapes in the same sketch?
A screenshot of the situation?
jrunsten is offline   Reply With Quote
Old   December 10, 2012, 04:44
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
Always the same question...
After creating the "surface from sketches", you have to freeze the created bodies (extras -> freeze).
Now there should be 3 different bodies in the project tree. Select them all, right click and select "form new part"
Now you are ready to go.
flotus1 is offline   Reply With Quote
Old   December 10, 2012, 05:28
Josef Runsten
My interpretation is that the bodies are supposed to be independent next to each other, ie not touching. But if they are touching, then yes that is the answer.
Old   December 10, 2012, 07:29
Yes they are touching and yes that was what i needed. Thank you very much!
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 07:34
[Other] Mesh Importing Problem cuteapathy ANSYS Meshing & Geometry 2 June 24, 2017 05:29
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
