[ICEM] HEXA mesh
Old   July 25, 2012, 05:38
Default HEXA mesh
Rémi Issac
freedomman is on a distinguished road
hello everyone,
I wanna figure out the hexa mesh of the geometry in attach, as you can see in the blk document, I try to dig out a little cuboid in the center. But I always meet the problem of Volume Orientation who is not able to be fixed, what I do is just delete those bad nodes. Then when I export this mesh to Fluent, it mentions Aborted due to critical error, non of the signs else.
Could you please take a look at of the blk where my mistakes are, what I can do now? cause I'm quite new in using ICEM and I spent pretty much time on this
Thanks a lot
freedomman is offline   Reply With Quote
Old   July 25, 2012, 07:53
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
I see many surfaces and curves which I think are unnecessary. Are you sure these surfaces and curves are necessary or only the centre cuboid and outer boundaries?
Far is offline   Reply With Quote
Old   July 25, 2012, 08:35
Rémi Issac
I was trying to give different mesh sizes to each part, but what is necessary is only the contour with the centre cuboid
Old   July 26, 2012, 10:22
Rémi Issac
I modified the blocking and move the bottom vertices of the cuboid, then I obtained a more flat angle for the sloping part . (as attached in main post)
Now there is no Volume Orientation problem any more, but when I export this new mesh to Fluent, it rejected with the same reason "Aborted due to critical error".
I can't find where the problem might be, could you please help me?
Old   July 27, 2012, 10:09
Far
Sijal
Done........ There is some trick in the blocking.
1. Merge vertices
2.Creation of Y-block
3. Another split for the dead block
4. Conversion the two blocks outside the geometry into dead block
PS: I have deleted all unnecessary curves, points and surfaces.
Old   July 27, 2012, 10:27
Rémi Issac
Many thanks, Far
I'll read it now
Old   July 27, 2012, 10:29
Far
Sijal
please uncheck the following parts (if they are enabled):
dead, solid and VORFN
Old   July 30, 2012, 11:42
cfd seeker is on a distinguished road
hi Far
What is the need of the dead block? have you associated some of its vertices with the geometry? and how it is separated from the geometry so that its not part of the mesh? Thanks
Regards
cfd seeker is offline   Reply With Quote
Old   July 30, 2012, 14:04
Far
Sijal
One picture is equal to thousand words and I guess one video is equal to thousand pictures. So here is the video for queries you have just asked
http://www.youtube.com/watch?v=ys1tO...ature=youtu.be
Old   July 30, 2012, 17:04
Rémi Issac
great............thanks
Old   July 30, 2012, 18:38
Far
Sijal
Originally Posted by cfd seeker View Post
hi Far
Regards
changing the material is same as when you delete the block and it goes to VORFN, therefore it disconnects itself from remaining mesh. When you uncheck that material from parts list it is no more part of active mesh (name does not matter, you can rename dead to live or even 007)
Old   August 1, 2012, 11:04
millions of thanks for the video and live, dead and 007 combination is itself deadly and suspicious :P
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
[ICEM] export hexa mesh to fluent Wieland ANSYS Meshing & Geometry 37 January 23, 2013 03:27
[ICEM] Hexa Mesh Smoothing Jules ANSYS Meshing & Geometry 6 December 4, 2010 18:00
