[ICEM] Hybrid meshing close to surface
Old   September 14, 2012, 12:54
Question Hybrid meshing close to surface
Kisorthman Vimalakanthan
k.vimalakanthan is on a distinguished road
Hi guys,
I have been able to create hybrid meshes using ICEM with the merge nodes > merge meshes function, for meshes that have large elements. But when I try to merge meshes with boundary layer and prism layer ICEM just freezes..
I was wondering if anyone have successfully created a hybrid mesh that includes a boundary layer on both sides i.e close to the surface. I'm trying to use very small initial height in the order of 1e-05. The tetra side of the mesh contains a prism layer and the hexa side contains O-grid boundary layer mesh. Both meshes have same amount of nodes on the curves/edges with similar distribution.
It's clearly been done using the meshing software Centaur (see attachment). I'm basically trying to recreate this mesh in ICEM.
Could anyone please tell if it is even possible to attempt such a thing in ICEM?
Any light on this matter is greatly appreciated
Kind regards,
Kishore
Dept. of Power and Propulsion
Cranfield University
Email: k.vimalakanthan@gmail.com
k.vimalakanthan is offline   Reply With Quote
Old   September 15, 2012, 21:05
PSYMN's Avatar
Simon Pereira
There is a tutorial about this (HVAC tutorial).
Basically, the ICEM CFD Merge meshes option only works if one side is all tetra... Then you need to add the prisms later...
It can be done, but it is a bit of a hassle. I know they are working on making it much easier, but that will be for a later version.
I have never seen it create anything like in your picture. But it would be pretty easy to get it to create a straight hexa mesh thru that region. Actually, I can't really understand why you even want to do that
CFD Online Users Survey
Old   September 15, 2012, 21:49
Firstly thank you very much for the much appreciated reply simon
Regards to the tutorial "HVAC tutorial", could you please send me a link for this tutorial as I could not find it on google or in the icem tutorial folder
Maybe you could please send it to my email: k.vimalakanthan@cranfield.ac.uk
From what I understand I have compiled the steps to create a boundary layer for a hybrid mesh. Could you please confirm if this is the correct approach for such a mesh:
1. Create Hex mesh with the initial node height (set on the blocking edges) being the maximum boundary layer height
2. Create tri mesh with the initial node height (set on the side prism side curves) being the maximum boundary layer height
3. Merge the intersection surface using merge nodes > merge meshes function
4. Generate Prism layers (both bottom surface from tri and hex are ticked for the prism layers)
Because I do remember trying such approach and failing but I will give it a try again. I think the tutorial you mention will help me a lot.
I did come across some other threads describing different approaches for this problem:
1. Using the "Existing quad layers" option to generate the prism layers - tried and failed to succeed
2. Splitting the prism after merging nodes- don't really understand this method
Could you please suggest if I should consider any of these above methods?
Regards to the picture, Im also not sure why they have computed such a mesh. I was able to generate such a surface mesh when I converted Hex elements to tri. I suspect that they have done this so the tri surface nodes aligns well with nodes from the hex surface at the hybrid intersection, thus merging nodes becomes easy. Unfortunately I can only speculate.
Kind regards,
Kishore
Old   September 15, 2012, 22:01
Forgot to mention that I'm also interested in reviewing on of your pdf named "Tips of ICEM 2008". Could you please send this one too.
Thank you
Kind regards,
Kishore
Old   September 20, 2012, 16:42
PSYMN's Avatar
Simon Pereira
I sent the 2010 one instead... I guess I am way overdue on an update for that also.
Old   September 27, 2012, 08:04
Default Reg. Tips of ICEM 20101
Raghav
raghav is on a distinguished road
Hi Simon,
Can u also share the same with me??
Regards,
Raghav M S
seetharamu.raghav@gmail.com
raghav is offline   Reply With Quote
Old   September 27, 2012, 08:13
PSYMN's Avatar
Simon Pereira
@raghav...
Done.
Old   September 27, 2012, 09:01
Red face
AB
BrolY will become famous soon enough
Hi Simon,
Could you also send it to me please ?
brolyrahmal@hotmail.com
Maybe you could upload it to a FTP, that would be easier for you !
BrolY is offline   Reply With Quote
Old   September 27, 2012, 09:44
Raghav
Thanks a lot
Old   September 27, 2012, 13:32
PSYMN's Avatar
Simon Pereira
ANSYS changed the policy and took down the old ftp site... I could post it in the customer portal, but a lot of you have trouble accessing that...
Old   September 28, 2012, 03:27
AB
Thank you Simon !
Old   October 6, 2012, 17:17
François Grégoire
macfly is on a distinguished road
@ Simon,
My turn please! Can't we share those pdf files on google docs or something?
I'm having a hard time trying to merge a complex fluid region mesh with a simple solid region mesh.
f.gregoire.3@gmail.ca
Thanks a lot in advance,
Regards,
François
macfly is offline   Reply With Quote
Old   October 10, 2012, 05:57
Tamil Nadu
nkme2007 is on a distinguished road
Hello All,
I want to do analysis of heat transfer from water flowing through pipes submerged inside concrete. I am modelling in GAMBIT and wish to analyse it on Ansys FLUENT.
Can anybody help me out, how to model and simulate?
Does any tutorials exist?
nkme2007 is offline   Reply With Quote
Old   October 15, 2012, 12:23
Default ICEMCFD Tips&Tricks 2010 pfd
  #14
ICEMCFD Tips&Tricks 2010 document
Originally Posted by PSYMN View Post
I got so many requests for this ICEMCFD Tips&Tricks 2010 pfd that I figured out how to share it over google docs...
https://docs.google.com/open?id=0ByI...nBqTXBQT3pQMjQ
Yes, it is well overdue for an update, but it can still help many of you.
Best regards,
Simon
Old   October 18, 2012, 23:20
François Grégoire
Thanks Kisorthman
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
Shared surface between bodies for better meshing? alxe ANSYS Meshing & Geometry 5 August 18, 2011 11:52
[ICEM] Automatic mesh generation script surface intersection problem stuart23 ANSYS Meshing & Geometry 0 May 13, 2011 01:10
[ANSYS Meshing] 2D airfoil hybrid meshing help! gusdlsrb ANSYS Meshing & Geometry 0 March 27, 2011 15:31
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
