[ANSYS Meshing] sweepable bodies & meshing
Old   October 30, 2012, 07:19
Default sweepable bodies & meshing
Sandeep
sandy_1982 is on a distinguished road
Hi ,
i have shell body , of 1 mm thickness
i want to make it sweep-able so that i can apply 'sweep-able mesh' method.
As a whole the body is not sweep-able, so i have sliced it into many parts
(to create a multi-body part) , now this is what i observe:
individually , the smaller bodies (created as a result of slice)are shown as 'sweep-able' in ANSYS Mesher, BUT when i unsupress the whole body in DM and take it to mesher , many bodies which were sweep-able individually , now have become unsweep-able.
Why is it happening and where i have to check it ..something wrong at the body-interfaces ?
Thanks
Sandeep
sandy_1982 is offline   Reply With Quote
Old   October 30, 2012, 08:53
Josef Runsten
jrunsten will become famous soon enough
Send a message via MSN to jrunsten
If the bodies are not frozen they will merge when you unsupress them. Is this the case for you?
jrunsten is offline   Reply With Quote
Old   October 30, 2012, 09:14
Sandeep
all bodies are frozen
Old   October 30, 2012, 09:18
Josef Runsten
Hard to say without having the files, can you upload an archive of the project?
Old   October 31, 2012, 23:34
Sandeep
PFA a word document having a picture of a multibody part
two bodies are in different colour
individually , each of the two bodies is sweepable
but when i unsupress both and generate mesh , i get this.
note that one edge seems to have collapsed at the interface which i have shown as encircled, is this the problem ? how to correct it ?
thanks & regards
Sandeep
Old   November 1, 2012, 04:07
Josef Runsten
If you upload an archive of the project it's way easier to help you. Is this the entire model? Or are there other parts connected as well? What method are you using for meshing etc..
Old   November 1, 2012, 08:04
Sandeep
hi ,
i am afraid , i can't upload the project for now
but to your other points :
it is not the entire model , its only a part of a shell - like body , which was imported from UniGraphics to DM
the approach i am following is to convert this shell body into sweep-able , for which i am slicing it accordingly - i intend to apply the 'sweep-able' mesh method once all smaller pieces of this whole body become sweep-able.
thanks
-sandeep
Shared surface between bodies for better meshing? alxe ANSYS Meshing & Geometry 5 August 18, 2011 11:52
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 05:22
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 11:09
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 11:08
