[ICEM] Problem with a nozzle and ambient volume |
December 14, 2012, 07:43 |
Davide
i'm trying to mesh a nozzle connected to an ambient volume; you can see the geometry pic attached. The nozzle have a small injector connected in the divergent. In the pics you can see the actual blocking and the premesh. I have managed to mesh the nozzle correctly using an O-grid, but i'm not able to mesh correctly the front faces of the ambient volume; as you can see in the premesh pic, i have several distorsion. Is there a way to mesh the front faces? Thank you! Geometry: http://s18.postimage.org/ibdnm9d5l/Geometry_post.jpg Blocking: http://s14.postimage.org/97uuwklqp/Blocking.jpg Premesh: http://s12.postimage.org/3pk3zk0bx/Premesh_post.jpg |
December 14, 2012, 08:26 |
Christoph
Rep Power: 18 |
It's always difficult to give a good advice without .tin and .blk-files. So it would be very helpful, if you could supply them.
But one for sure: you've to insert another o-grid to resolve circular shape of the outer volume. I can't see the details, you're talking about on your pics. So please supply the files or give us some more detailled pics. Regards Christoph |
December 14, 2012, 09:02 |
Davide
here is the file.
thank you for the help! |
December 14, 2012, 13:18 |
Some advance blocking techniques were needed to get this mesh.
Like creating three o-blocking, deleting few blocks permanently and few without permanent option. Deleted middle o-block, merged vertices, some were not merged. Extrude along curves option was also used. You can further improve quality by adjusting edge mesh parameters and vertices. |
December 15, 2012, 05:40 |
Davide
you've done an amazing work here, thank you very much for the help!!!
i'll try to replicate your work; in case of problems, i'll ask here for some advice. thank you again! =) |
December 15, 2012, 06:53 |
You can use your old blocking effectively if you change your outer domain into rectangular shape. Every will be perfect !!!
I am also attaching the intermediate blockings so that you can understand where to start and what to do step by step. Especially pay attention on blocking 3 and blocking 4 where I made three O blocks and deleted middle o-block. b Also 5 to 10 where I am performing merge operations and association to edges. Blocking 12 with extrude along curve for. Compare blocking 10 with 12 inside the nozzle. Do not follow blocking 17. First I tried to make the blocking in the injector. Then I deleted and instead first made the o-blocking in side the nozzle and carried into towards the far-field. Then extrude the blocking for the injector pipe and then made the o-blocking for the injector. Got it??? Hope it helps. |
ambient volume, icem 3d, nozzle |
Shock in nozzle - when | Christian | Main CFD Forum | 5 | September 20, 2014 09:26 |
Probelm with supersonic exhaust to ambient | newj | CFX | 2 | August 9, 2012 18:01 |
Supersonic nozzle exit conditions | Betty | Main CFD Forum | 13 | May 24, 2012 00:26 |
compressible flow in a counterflow nozzle | d.vamsidhar | FLUENT | 0 | November 24, 2005 01:45 |
nozzle jet solution by compressibe and incompressi | minun | Main CFD Forum | 2 | September 7, 2000 08:23 |
