[ICEM] mesh at the corner: bad quality
Old   December 18, 2012, 09:00
Post mesh at the corner: bad quality
hz283 is on a distinguished road
Hi All,
When I generate the mesh for a square chamber using tetra/prism mesh, I found that the cells at the corners of two walls always have bad quality (as shown in the attached figure). Does anybody know how to improve the quality of the mesh there? Thanks.
hz283 is offline   Reply With Quote
Old   December 18, 2012, 11:45
Bruno
brunoc is on a distinguished road
Try using smoothing the surface mesh using the Laplace algorithm (set the volume elements to 'Float') several times, then regenerate the volume mesh using the Delaunay method.
brunoc is offline   Reply With Quote
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
[ICEM] Tips for 3D tetra mesh quality for Fluent transient run. Rotary Engine Catthan ANSYS Meshing & Geometry 0 June 18, 2012 12:46
[snappyHexMesh] mesh quality control and fix tachyon_me OpenFOAM Meshing & Mesh Conversion 0 October 6, 2009 12:48
