[ICEM] how to generate unstructured mesh in two region |
December 20, 2012, 07:43 |
I have geomery region as shown in attachment. it is a solid square in square cavity.
I want to generate meshes in these two regions. but i met troubles about how to define these two regions and how to name it with "solid" and "fluid". regards |
December 20, 2012, 10:48 |
Dongyue Li
Rep Power: 17 |
Hi ~ just delete the solid body, so ICEM wont generate mesh in it. you just get mesh on fluid part.
December 20, 2012, 21:14 |
December 21, 2012, 03:04 |
AB
Rep Power: 21 |
specify the walls around the solid as internal part.
December 21, 2012, 08:36 |
December 21, 2012, 09:36 |
AB
Rep Power: 21 |
Mesh -> Part Mesh Setup
Use the help button in ICEM and you will find a lot of answers |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
[ICEM] unstructured mesh to surface patch dependent | Sheyko | ANSYS Meshing & Geometry | 5 | December 20, 2011 04:29 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
