[GAMBIT] Mesh error while trying to read it using Fluent
Old   January 4, 2013, 03:47
Default Mesh error while trying to read it using Fluent
Usman
dk_damo is on a distinguished road
I designed and mesh my combustor chamber using gambit then i tried reading my case with fluent but it fails ,did all i can to remesh or change things but still fails.
This is the error below i got when reading the case.
Loading "C:\Fluent.Inc\fluent6.3.26\lib\fl_s1119.dmp"
Done.
> Reading "C:\Users\dk\Desktop\combustor final 18DEC\combustor with fuel inlet\combustor with fuel inlet.msh"...
102703 nodes.
75 mixed mass-flow-inlet faces, zone 3.
6292 mixed wall faces, zone 4.
17202 mixed wall faces, zone 5.
14044 mixed wall faces, zone 6.
18556 mixed wall faces, zone 7.
272 mixed pressure-outlet faces, zone 8.
126 mixed mass-flow-inlet faces, zone 9.
560306 mixed interior faces, zone 11.
269232 mixed cells, zone 2.
Building...
grid,
Note: Separating wall zone 7 into zones 7 and 1.
wall.3 -> wall.3 (7) and wall.3:001 (1)
Removing 75 unreferenced faces, zone 3.
Cell Centroid is xc 51.793619 yc -0.799997 zc -4.593363
WARNING: no face with given nodes. Thread 2, cell 185542
Error: Build_Grid: grid error.
Clearing partially read grid.
Error: Null Domain Pointer
Error Object: ()
dk_damo is offline   Reply With Quote
Old   January 4, 2013, 03:59
-mAx-'s Avatar
Maxime Perelli
can you post a picture of your geometry?
did you split it? (sounds connectivity problem)
Old   January 5, 2013, 12:13
PSYMN's Avatar
Simon Pereira
Null pointer means that you have an uncovered face... A volume element at the boundary without an adjacent shell element for Fluent to apply the wall boundary to (or a shell without a line boundary in 2D).
Maybe mAx can tell you how you got that with Gambit (it is easy to make that mistake in ICEM CFD ) Did you delete any shells?
CFD Online Users Survey
Old   January 5, 2013, 13:12
Usman
Thank you,YES. The error started when i deleted an earlier swirler then i designed a new modified one which i replaced.
Old   January 7, 2013, 01:12
-mAx-'s Avatar
Maxime Perelli
Then the old design may not be deleted properly, and it's surface mesh may remain
Old   January 7, 2013, 06:42
Default thanks
Usman
Thank you Max,did you get the files i sent to you?
Old   January 7, 2013, 09:44
-mAx-'s Avatar
Maxime Perelli
no
private message?
Old   January 7, 2013, 09:52
Usman
no
private message?
Yes,Max i sent it private maybe i mistakenly sent to a different email,can you kindly confirm your email to me,i wanted to send the cad n mesh files which i still get that error i posted . thanks again
Old   January 7, 2013, 10:26
Default email
Usman
hi, Max i sent .thanks
Old   January 9, 2013, 01:18
-mAx-'s Avatar
Maxime Perelli
ok not surprised that you get errors in fluent.
you have to restart from beginning. (split problem, connectivity problem and topology problem).
Did you build the geometry in Gambit or did you import anything from cad?
Old   January 9, 2013, 04:31
Default hi
  #11
Usman
Thanks Max i did it in Gambit
Old   January 9, 2013, 04:35
-mAx-'s Avatar
Maxime Perelli
describe shortly how (till you get geometry without any decomposition)
Old   January 9, 2013, 05:11
Default hi
  #13
Usman
Max what happen was i designed and meshed a swirler and a combustor separately then combined them together i was able to run a case in fluent without a problem then i noticed i needed to modify the swirler with introduction of a boundary called fuel in and this swirler i entirely new from the earlier one then i tried to combine both as i did thats when fluent failed to read it.
Old   January 9, 2013, 05:26
-mAx-'s Avatar
Maxime Perelli
I am curious to see the fluent results.
Basically in your model you have an outer box and a swirler, and I can move the swirler anywhere whithout Gambit checked anything.
That means that Gambit treats the outer domain without any hollow , and on the other hand, Gambit has another separate domain: the swirler
From beginning you need to model the outer domain, and also the swirler (but this one as solid). Then substract the outer domain with the solid.
Once it is done, you can go and split.
Do you have a sketch of your model (not gambit)
Old   January 9, 2013, 06:22
Default hi
  #15
Usman
Hi,Max i sent more info about the problem to your email.thank you very much))
Old   January 10, 2013, 01:34
-mAx-'s Avatar
Maxime Perelli
-build the combustion chamber as solid first like page 7 (take care of thickness)
-build the swirler separately as solid and place it to its right place.
Once you assembly is done (as solid), create a bounding box and substract the assembly from the box.
It would extract the fluid domain, and you could start from a clean geometry.
Old   January 10, 2013, 06:32
Default hi
  #17
Usman
Ok,thank you Max
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 03:34
Fluent reads mesh file well, but error when mesh checking jyoung79 FLUENT 3 November 13, 2012 05:50
Can Fluent handle a degenerate block? Error while reading mesh... Anorky FLUENT 1 May 1, 2010 12:47
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 14:37
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
