[ICEM] How ICEM export mesh can be used in CFL3D
Like Tree1Likes
  • 1 Post By PSYMN
Old   October 29, 2012, 00:55
Default How ICEM export mesh can be used in CFL3D
Wang
M201170944 is on a distinguished road
i have created a 3d cube mesh,want to export to CFL3D.According to some advise,Pre-mesh>Convert to Multiblock Mesh>Select Solver,then i donot know the how to select (Output Solver and Common Structural Solver) ,and also wonder the XYZ file and INP file ,Help me
M201170944 is offline   Reply With Quote
Old   October 29, 2012, 10:48
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Here is the help on CFL3D
http://ansys.com/staticassets/ANSYS/...aces/cfl3d.htm
I would need more info to answer why it is failing for you... Can you give me more about your steps and the error message?
You should right click on premesh to convert to multiblock mesh, then you should go to output tab => solver Setup and choose CFL3D as your Output Solver... Then go into Output => Boundary Conditions and set that up (as shown in the above link). Even if you don't want to set that up, you must still open it and hit OK to create the file. Then Go to Output => Write Input... Follow all the prompts and don't forget to save your project...
Don't worry about the "common structural solver" unless you are setting up an FSI run where you will be using a structural solver.
Actually, I just tried it myself and it failed, but maybe I did something wrong with the boundary conditions, but it is complaining about a family that I don't have. I will submit a defect. Still get me your error message and I will add it to the defect if it is different to mine.
Far likes this.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   October 29, 2012, 21:09
Default Thanks
Wang
Thanks for the replay ofrom Far
I haved tried as your advise but failed as the same as what i met before .
Here is my process:
(1)Pre mesh>Convert to Multiblock Mesh,create the cube.Multiblock
(2)Output>Select solver>Output Solver CFL3D/Common Structural Solver Nastran
(3)Set the Boundary Conditions
(4)Write Input,select the cube.Multiblock and clock Open,nothing happens,only i chose cancle ,then the CFL3D ariseddesktop.jpg
select>Done
then set the parametersparameters.jpg>Done
next comes the ERROR.i am so confused about this and do not know how to handle thiserror.jpg
Old   February 4, 2013, 16:47
PSYMN's Avatar
Simon Pereira
I get the same error message UNLESS I allow it to save the project before outputting to CFL3D...
ICEM export mesh Youen ANSYS Meshing & Geometry 34 April 23, 2017 12:15
How to export multizone uns mesh from icem to cgns july CFX 1 May 1, 2013 09:59
[ICEM] Export ICEM mesh to Gambit / Fluent romekr ANSYS Meshing & Geometry 1 November 26, 2011 12:11
export mesh from ICEM to CFX alinik ANSYS Meshing & Geometry 5 June 20, 2010 14:38
How to Export ICEM mesh to ANSYS Structural SIVAPRAKAASH CFX 4 December 27, 2007 23:54
