[ICEM] mesh in-dependency and mesh quality control
Old   February 20, 2013, 02:06
Default mesh in-dependency and mesh quality control
Sujay
sujay is on a distinguished road
Dear All,
I need help in mesh in-dependency and mesh quality control.
My geometry has submerged pipe, hence it has few single edges and multiple edges. Will they affect simulation ?
During mesh quality check i get, message like Multiple edge, single Egde and Delaunay Violation asking for sub set creation. How to tackle this problem ?
During build topology, inlet & outlet which are circle gets subdivided, therefore i am not using build topology. Is it necessary to apply build topology for geometry. I am constructing whole geometry from vertices.
For Meshing i am using smaller size at inlet and outlet (Max size 4 mm) through part mesh setting and for rest region through Global mesh size (Max Size).
With fixed max mesh size for inlet and outlet, I want to set global mesh size. The change in total element and node is as below,
Global Mesh Size (Max) Total Element Nodes
64 mm 414383 72421
32 mm 461344 80527
16 mm 841709 145118
How total element/nodes depend on Global mesh size? Please guide to select mesh size for mesh in-dependency.
Thanks Sujay
sujay is offline   Reply With Quote
interFoam: timestep / mesh / PISO nCorrector dependency linch OpenFOAM Running, Solving & CFD 16 October 31, 2019 04:24
InterFoam mesh dependency nimasam OpenFOAM Running, Solving & CFD 14 November 10, 2015 14:42
Mesh dependency - possible that refinement = worse results? crisgc FLUENT 4 November 14, 2012 12:16
Mesh dependency of gradient scheme bsiyahhan OpenFOAM 0 October 15, 2010 08:18
Dependency of turbulence model on mesh size Kushagra Mittal CFX 1 September 20, 2007 18:51
