[ANSYS Meshing] Skewed mesh
Old   February 18, 2013, 11:32
Default Skewed mesh
Megan Wood
mwood is on a distinguished road
Hello
I am using Fluent 14.0.
I have a setup that involves pipes meeting a chamber at a 90 degree angle. I am getting highly skewed grid at the ring where they meet.
Does any one know how I would fix this?
Thanks
mwood is offline   Reply With Quote
Old   February 18, 2013, 11:59
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
post some pictures so we can see what's going on...
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   February 18, 2013, 12:47
Megan Wood
So these show the meshed chamber with the pipes and then where the mesh is highly skewed.
Old   February 18, 2013, 14:58
diamondx's Avatar
Ghazlani M. Ali
have you used in specific method to generate the mesh ?? like multizone ??? have you got tutorial on how to mesh with ansys meshing ? if not, i can provide you with tutorials. my knowledge in ansys meshing is very limited
Regards,
Ali
Old   February 19, 2013, 09:08
Megan Wood
I am using the inflation tool
Old   February 19, 2013, 16:43
diamondx's Avatar
Ghazlani M. Ali
Go back to designmodeler, see where you have the intersection of the pipes with the square, make a slice there, the slice will result in multiple part, select them all, right click and select FORM NEW PART. now back to the mesher, select each part, right button click, insert multizone. do that for all the part. I'm not very proficient with ansys meshing but i saw a lot of thread discussing about this method. try it . moreover i can pass you the tutorials they are available in the customer portal
Regards,
Ali
chamber, mesh, pipe, skew
[ICEM] Problem making structured mesh on a surface froztbear ANSYS Meshing & Geometry 4 November 10, 2011 08:52
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
help: the volume mesh has highly skewed elements xiaofish FLUENT 3 September 18, 2007 09:51
Skewed mesh simulations Christopher Peacock FLUENT 2 September 3, 2007 07:06
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
