[GAMBIT] gambit meshing for the flow passing a 3D cylinder
Old   February 21, 2013, 14:51
Default gambit meshing for the flow passing a 3D cylinder
babak
babak4s is on a distinguished road
Hello everybody,
I am trying to create a structured 3D mesh around a circular cylinder located at the middle of a room (domain). The problem I faced is that how to create such a mesh when I want to mesh the above domain of the flat plane of the cylinder? for example, if we consider a cylinder like attached photo, how we can create a structured mesh for domains located out of the paper?
babak4s is offline   Reply With Quote
Old   February 22, 2013, 01:57
-mAx-'s Avatar
Maxime Perelli
create your domain like in the picture:
box with cylinder hollowed.
Then use split tool to divide the volume into 5 subdomains, like in the picture.
Once it is done, go and mesh each subvolume with hexa.
Old   February 23, 2013, 08:12
Default Thanks but...
babak
thank you for answering me. you mentioned me a picture but there is no picture to be seen here! which picture do you mean?
Old   February 25, 2013, 02:09
-mAx-'s Avatar
Maxime Perelli
your picture
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 13:00
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 11:47
[GAMBIT] meshing in GAMBIT, a flow through a pipe having complex inflow geometry mazhar1613 ANSYS Meshing & Geometry 1 January 11, 2012 23:18
flow around a cylinder pXYZ Main CFD Forum 14 July 25, 2011 10:05
Meshing Aircraft with Gambit Ed FLUENT 5 November 9, 2004 05:04
