[ICEM] Help needed in ICEM meshing
Like Tree6Likes
Old   February 26, 2013, 07:18
Default Help needed in ICEM meshing
nauman hashmi
nauman55 is on a distinguished road
hi need help in meshing of an aircraft wing attached as picture.
regards
blgypeng likes this.
nauman55 is offline   Reply With Quote
Old   February 26, 2013, 12:13
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
If you follow the wing body tutorial and some techniques to mesh the region inside the tip (a thread started by cfd-seeker and some other threads), you should be able to get a decent mesh.
If you want us to try, then share the files.
Far is offline   Reply With Quote
Old   February 26, 2013, 14:00
Default Re
nauman hashmi
Far sir i have tried that wing body tutorial and changed my blocking strategy but the pre mesh i got had negtive volumes and uncovered faces. sir may i know in which format i shud upload the geomerty? ansys or the parasolid file?
regards
Old   February 26, 2013, 18:19
Max
mraxx is on a distinguished road
I have a similar problem. I spent hours on trying to mesh this geometry and almost threw my computer out of the window. The attached picture shows a medley of some of the worst outcomes of my attempts
Far, since you offered your help to naumann55, maybe you can have a look at my ICEM project and see if you can fix it. I do not really care about perfect mesh quality. Your help is greatly appreciated!
Here is the ICEM project file: http://www.file-upload.net/download-...irbus.zip.html
Also, I have some questions... maybe answers to this questions would bring me closer to generating the mesh by myself.
1. The ragged trailing edge shown in the picture below can be fixed by lowering the edge criterion, right? Because this did not seem to work for me but maybe I did not go low enough.
2. Many times, ICEM did not only mesh the FLUID domain but simply meshed through the surfaces. What am I doing wrong? What I did is I created a FLUD body and a SOLID body in the aircraft. When computing the mesh, I turned of the SOLID and selected Input Geometry: Visible.
3. Why are there almost never prisms on the surfaces although i specify prisms in the part mesh setup, in the prism meshign setup and check "create prism layers" in the computer volume mesh section?
4. I created a surface through the body of the aircraft as symmetry plane. ICEM created a surface mesh on this plane. But this surface mesh is also on the part of the surface that lies inside of the aircraft body. I would expect that to be a problem for the solver. Do I need to cut the inside of the aircraft out of the symmetry surface?
Thanks in advance for your answers!
mraxx is offline   Reply With Quote
Old   February 26, 2013, 23:56
Far
Sijal
wow classic. I will try on model as I have never seen such a Beauty in my life. Awesome
All day, every day
cesarcg likes this.
Old   February 27, 2013, 05:46
nauman hashmi
sir sent you the geometry file on your email. request acknowledge reciept.
regards
Old   February 28, 2013, 12:44
Far
Sijal
There were many problems in geometry including outer surfaces, wing and fuselage. Corrected them but the fuselage surface cannot be rebuilt in ICEM and it must be corrected in your CAD software or design modeller.
Old   February 28, 2013, 12:58
Default Blocking
Far
Sijal
Old   February 28, 2013, 13:48
Default thanx alot sir far
nauman hashmi
thanx alot sir i will do that. i request if you can email me the blocking and mesh you have created. get back to you after repairing the highlighted area.
regards
Old   February 28, 2013, 14:01
Far
Sijal
same blocking can be reused. Similar approach is used as used in Simon's three part tutorial on airfoil meshing.
Can you think of any other topology? like wing body tutorial? what do you think which one will be better?
nauman55 likes this.
Old   March 1, 2013, 14:30
Far
Sijal
Look at the pictures. I have used edit edge > Automatic linear and you can notice there is unexpected deflection of one edge in lower portion of fuselage.
Old   March 1, 2013, 15:00
Default Problem solved
  #12
Far
Sijal
Problem solved by dividing fuselage into two parts spanwise. Sending you files... And same blocking was re-used...
Quality > 0.61 and min angle > 18
Procedure to divide fuselage into two surfaces:
1. create iso-curve at 0.5 location on both sides (pressure and suction)
2. Segment surface by created curves.
3. update association and also make some manual association at newly created air-foil (edge to curve and vertex to point)
Enjoy at RCMS with KP...
cfd seeker likes this.
Old   March 1, 2013, 15:11
Far
Sijal
@Max:
I took a look at your problem and I found it interesting. I remember similar problem at AIAA drag prediction workshop and meshing was done in ICEM hexa and tetra.
I can try to reproduce both hexa and tetra meshing if you are interested...
Old   March 1, 2013, 15:40
Far
Sijal
No problem in Fluent. Please turn of "solid" when you are generating unstructured mesh.
Old   March 2, 2013, 00:32
Default import to fluent
  #15
nauman hashmi
sir it is still not readable by fluent. the error message says of some missing faces. may be i have messed up with the boundary conidtions.
regards
Old   March 2, 2013, 01:10
Far
Sijal
As you can see in above pic, mesh has no problems in fluent.
Old   March 2, 2013, 06:07
cfd seeker is on a distinguished road
Hilarious
Far likes this.
cfd seeker is offline   Reply With Quote
Old   March 3, 2013, 07:26
Max
Originally Posted by Far View Post
@Max:
Yes, I am more than interested!
Old   September 27, 2013, 06:54
rajendra singh
raj.singh is on a distinguished road
is O Grid possible for such blocking???
raj.singh is offline   Reply With Quote
Old   September 27, 2013, 17:56
Cesar
cesarcg is on a distinguished road
Send a message via Skype™ to cesarcg
Dear mraxx,
I took a look at your geometry and saw that some surfaces at the tail of the fuselage were not cut, and thus these are outside of the fluid domain. The command "split surface by plane might be applied". I also saw that you model have many details at the inlet of the engine that can be omitted in a first approach.
Moreover, in my experience I think that the hardest part of the meshing will be at the regions where the wing, and stabilizers (vertical and horizontal) join the fuselage; as well as where the engine joins the wing. It is probably better to use tetra/prism in such regions as suggested by @Far.
@Max:
I'll try to help during my free time.
Regards,
César
cesarcg is offline   Reply With Quote
[ICEM] problem with meshing in icem cfd saurabhjoshi2011 ANSYS Meshing & Geometry 13 March 12, 2013 11:27
[ICEM] Help needed regarding meshing of T junction selvam2487 ANSYS Meshing & Geometry 0 February 25, 2013 04:27
[ICEM] 2d Aerofoil meshing in ansys ICEM syler3321 ANSYS Meshing & Geometry 2 February 3, 2012 01:59
Wind tunnel hexa meshing in ICEM CFD 12.1 matheusguzella ANSYS Meshing & Geometry 1 March 14, 2011 16:14
ICEM meshing question gsbhatia89 ANSYS Meshing & Geometry 0 June 10, 2010 08:29
